Multi HVAC Blower Motor Failure
Old 02-19-2019, 01:26 PM
Automotive Tech
Pir8pete's Avatar
Angry Multi HVAC Blower Motor Failure
This will be the 3rd time I'm replacing the hvac blower motor in this shit 2016 ILX. When replacing it the 2nd time I took the motor apart to see what was making this faint burning smell and sure enough the bearings where eating it's self and aswell as the brushes and the turbine, creating this very fine dust that when checking the tubing vents right after the blower motor where coated with it. I wiped down the inside on the vents as far and I could reach and replaced the blower motor. Now it's doing it again 3rd time this is just another stupid Honda design.
-When I install it myself 30 day warranty
-The dealer installs 1 year / 20,000 kms
ILX now has 232,000ish kms
Takes 10 mins to replace, remove plastic cover with pull tabs and the motor has 3 screws and unclip the wire harness , so I'm going to get the dealer to do it this time as I'm sick of paying $70CAD for a motor every year.
I get the dealer to save the old motor and will take it apart to pictures to post here.
Now my question is does any one here notice this or are you all just a oblivious!!! because it know it happening you guys just don't pay attention!!! I bet you guys don't even replace the cabin air filter.
Number 10;
https://www.acuraoemparts.com/auto-p...er-blower-scat
Old 02-19-2019, 03:28 PM
schen72's Avatar
We see your post but I haven't had the issue you have. You've driven 232k kms on a 2016 ILX? My 2016 has about 10k miles on it.
Old 02-19-2019, 07:08 PM
Automotive Tech
Pir8pete's Avatar
well with 10k you won't see any of these symptoms, that's like comparing one from the show room, c'on man! and yes, 236,664 kms as of today
Old 02-19-2019, 07:26 PM
Automotive Tech
Pir8pete's Avatar
As you guys can see the brushes are wearing the contacts on the shaft and creating fine copper and lead dust. This can't be good to breath in over time. I will be contacting Honda customer relations. I'm ashamed with anyone having a good amount of kms/miles that own any of the Acura's that share the same blowers 2013-2019 ILX ALL plus the RDX ALL use the same part number. That are ignorant / oblivious to what's happening. I 100% guaranty yours is doing the same thing and your breathing it in your just noise blind.
Old 02-19-2019, 07:37 PM
Automotive Tech
Pir8pete's Avatar
If people want to check yours it's easy and takes 10 mins if that, here's how;
- remove cover, pull down near the 3 pull clips then remove the bulb and wire by turning top down towards you.
- remove blower, unplug wire hardness big white clip and wire clip to give more slack, support blower with hand and remove 3 screws, use socket 8mm is easiest.
Now to check if your blower has built up dust shavings inside, tilt sideways and lightly tap on counter, either some will fallout or at least you can view inside the space where the white fan blades and the motor housing is. also you'll smell a faint burnt smell. good luck
As I said this is my 3rd time replacing this; so that means the original 1 failed, plus 2 replacements now, and they all did the same thing. Had the car on the road since June of 2015
Old 02-19-2019, 08:30 PM
DaIll1's Avatar
I only have 15k miles and don't use the blower much, but it looks like they need a softer/higher lubricity material for the brushes.
Old 02-19-2019, 08:59 PM
Automotive Tech
Pir8pete's Avatar
15,000 miles = about 25,000 kms, not even close yet but I'm sure it's starting, and yes correct, they need to do a re-design, Honda is still actively using this on their new 2019 models too.
And why do you drive around with the blower turned completely off? either you like wind noise or stuffy cabin air.
Old 02-19-2019, 09:01 PM
Automotive Tech
Pir8pete's Avatar
as you can see with my screw driver I'm pointing to the deep grove and the lip worn in from the brushes
It's crazy how much shorter these brushes are compared to new ones.
this is what we are breathing in guys over time, can't be good, I can smell it getting worst and worst over time, same pattern after replacing. We see what Honda has to say about this!!!
Old 02-19-2019, 09:05 PM
Automotive Tech
Pir8pete's Avatar
Admins can you sticky this
Old 02-20-2019, 01:07 PM
DaIll1's Avatar
Isn't that why they cut a hole in the roof?
Old 02-20-2019, 01:31 PM
Automotive Tech
Pir8pete's Avatar
Lightbulb
again wind noise
Old 02-20-2019, 01:46 PM
Automotive Tech
Pir8pete's Avatar
so the dates of buying the blowers are as followed;
- bought the car and on the road June 2015
- replacement 3/8/2016
- replacement 3/7/2017
- replacement again now in 2/19/2019
Old 02-21-2019, 02:17 AM
schen72's Avatar
Well, it's definitely disappointing that this blower seems to have a design flaw. I guess you're the first to encounter this due to your super high miles.
Old 02-21-2019, 03:15 PM
Automotive Tech
Pir8pete's Avatar
it doesn't take that long or that many kms / miles before it starts to happen, look at how many times and the dates of when i bought this car new to when i replaced the blower motor.
This will be happening to the avg. user that puts 25,000 - 30,000 a year, if you have close to 100,000kms or 62,137 miles take your blower motor out tilt it sideways on a table and lightly bang it, you'll see the fine dust metal shaving come out and or look in inside between the white fan blades and the black housing and you'll see yours is doing it too and your breathing that in. Don't be scared it takes all of 10 mins to do.
Old 02-21-2019, 03:57 PM
Automotive Tech
Pir8pete's Avatar
Arrow
Submitted an official complaint with Honda/Acura Canada about this issue.
My dealer Gat. Acura will also be contacting the Tech Hot Line to submit there info on this issue, could take up to 6 month to hear back. Do not go to Camco Acura dealer they will not help when it comes to very technical issue's like this, just warring people to avoid a headache.
Inquiry/Question
Thank you for giving us the opportunity to address your inquiry.
Please accept this message as confirmation that your email has been received and placed in queue. We have assigned case number (01295700) to your email. Please be advised response times are dependent on our queue volume. We strive to address all inquiries within two business days.
Have a great day!
The Acura Canada Client Service Team
Merci de nous donner l’occasion de répondre à votre demande d’information.
Veuillez accepter ce message à titre de confirmation que votre courriel a été reçu et placé dans la file d’attente. Nous avons attribué le numéro de cas (01295700) à votre courriel. Nous vous informons que les délais de réponse dépendent du volume de la file d’attente. Nous nous efforçons de répondre à toutes les demandes d’information dans les deux jours ouvrables.
Bonne journée.
L’équipe des Services aux clients d’Acura Canada
Old 02-21-2019, 05:15 PM
Received 8,583 Likes on 6,630 Posts
How much?
Let me know so I can send you my paypal address and you can pay me
Old 03-28-2019, 01:11 PM
Automotive Tech
Pir8pete's Avatar
it's a good thing your a moderator
Old 04-25-2020, 04:58 AM
Mr Jun1or's Avatar
I think you may have just solved my issue! Had my own thread for this same exact thing. Check it out .https://acurazine.com/forums/acura-i.../#post16568959
here’s a video of the actual chirping coming from he motor. Towards the end of the video, I shut the AC off and and you can hear a wheel like sound that goes with the chirping: https://www.youtube.com/watch?v=SWXG...ature=youtu.be
Old 04-25-2020, 05:27 PM
Automotive Tech
Pir8pete's Avatar
yeah man order a new one and just replace it yourself its very easy and will take 5 mins to complete, but it will come back again
Netspeed
03-24-2016 12:07 PM
Unkn0VV17
12-14-2010 02:10 AM
TLdream
11-04-2009 10:43 AM
03-24-2009 02:31 PM
CleanCL
05-26-2006 06:00 PM
Quick Reply: Multi HVAC Blower Motor Failure
