First Acura - question about normal sounds
Just got my first Acura. 2016 ILX premium A Spec. I always had crappy cars before so this is my first nice one! Has 23k miles, one owner and no accidents.
I may just be making something more than it is in my head, since I have always had terrible, unreliable cars.
It just seems like when I am going slow and gears are shifting down, that it makes a "tick" noise. Not a loud thud but a tick or kick down. Also when I am idle and tap the gas, it also makes a little noise like that. Is that normal? I mean, do gears make noise when shifting down? When I tap the gas when going fast I don't really hear it, only when at like a stop sign (rolling stop). I don't know, I just get nervous with a new car and want to keep it in as good as shape as possible. It almost sounds like running over a small twig or something, when It shifts down or something. Again, not familiar or a mechanic, I just want to see if SOME sounds are normal. Thanks
Did you get this TSB performed?
Your ILX has a DCT which is different than a standard automatic. I have noticed that in low speeds, such as stop 'n go, it sometimes feels a little "clunky" and not perfectly smooth. But this TSB supposedly helps to smooth it out. I had it performed just because it was free and I can't tell any difference.
TSB 17-015 - 8-Speed Transmission (DCT) Has a Bump or Hard Shift When Coming to a Stop
Applies To: 2016–17 ILX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B17-015.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-015.PDF
Don't forget about the Front Passenger Axle recall
Recall #G54 2016-19 ILX Driveshaft Separation
http://www.urvi.net/forumfiles/SB/B19-035.PDF
How do I get that performed? The links your provided didn't lead anywhere. Do I have to take it to a dealer and what would the cost be?
What do you mean by that? Maybe it will sound like what I am experiencing? Thanks. I do want to call Acura about the recall and let them know the noise I hear, which does sound like underneath. Not a lot, but some when slowing up almost a clinkk but not a deep thud. Maybe an axle sound now that I read the recall
And my carfax says At least 1 manufacturer recall requires service. Locate an authorized Acura dealer to obtain more
information about this recall but when I enter the vin it says it checks out? How do they know my car is fine? I see nothing in the carfax that shows it was fixed by the dealer. I would hate myself if I have to start kicking money into this 2 weeks after I bought it, with 23k miles!
a TSB is not a recall.
A TSB is a "Technical Service Bulletin" which basically means some work is required to fix non-safety issues.
a recall generally involves safety issues.
also realize that you dont have a "normal" automatic transmission....it's a DUAL CLUTCH TRANSMISSION, or DCT...which will behave and sound VERY different than a normal automatic transmission
I didn't understand the "not falling out" part? What do you mean? Also if my carfax says the model has an active recall but my VIN shows it doesn't what do I do. Especially if it seems like what I am hearing is related to the recall reason?
but you can visit a dealer and test drive other ILX's to check.
This would be more ideal than asking how to describe noises through text...
because there's only so many words for clicks,thumps, clunks, electrical whirs that one can write out.
Test drive other ILX's to see if yours sounds similar.
he's saying, his car is in perfect condition...the car did not breakdown
I looked at the .PDF that outlines the recall...
it's an axle recall. the axle might have not been properly installed and may popout which would lead to loss of power, not driveable....and may move when parked.
You are correct that bad axles make a clicking sound. but like stated above, noone can describe noises properly through text.. IF YOU ARE concerned, visit a dealer.
The transmission is a computer controlled manual transmission with a lockup torque converter. It will make gear clunk sounds like a manual with quick throttle input.
From everything I've read, it is one of the best dual clutches for driving in traffic.
Also, please understand the difference between TSB and recall. TSBs are like small problems that are discovered early on. These do not affect safety. If you are under warranty, they are free to perform. Even if you're out of warranty, they might still do it free. This DCT is indeed very smooth. Just be aware it does not feel like a conventional automatic.
Recalls are safety related and regulated by the government. They are free regardless of warranty.
What I mean is, there are clicks, pops, buzzes, and whirs not normally heard in mechanically controlled cars.
The TSB (that my VIN was covered under) is for an axel coming out (falling out). It's only a small number of cars that may need repaired.
Hey, thanks! That helps and I think that sounds like what I hear, I am just not used to a newer car or this engine. Been driving a beat up CrV 2002 for 10 years so I am not sure what a decent engine even sounds/ffels like. I just want to make sure that I have a good car! Thanks again!
I've been chasing after this exact noise on my 2018 since I purchased it new. 5 visits to 2 different dealers and I was told its normal. Emailed acura Canada and same response. Had all TSBs performed included the new chain tensioner replacement one and the cv axle replaced even after being inspected and passing as ok for the recall. Not truly happy about it but guess I've got to live with it. Only strange that the 2.4l TLX doesnt do it with the same drivetrain.
It absolutely does. I had a TLX as a loaner while my dealer was installing door edge guards and investigating a clunking noise of my own (diagnosed as a faulty front strut, replaced under warranty), and the difference in quietness between it and my ILX was night and day.
If you drive in S mode, it's really lively. It basically locks out the top two gears and doesn't shift as early. I imagine it destroys fuel economy though.
I drive in sport mode often, I just think the lower gearing would really wake it up. Gear ratios make huge differences. It would also play havoc with the AWD the ILX has (A wheel drive, as in single) and flashing lights on the dash don't make it launch better.
How do you deal with the injector noise inside the cabin while driving in Sport mode? All I hear is the ticking sound until you really rev it out.
I don't have usual injector noises, I use Aces IV fuel additive. So much goodness in that bottle. And yes Quantum Blue motor oil. BND knows how to make the Earth Dreams happy.
edit: I understand it's tuned for 92 octane, but it really makes a difference in how well it runs.
I get my oil changed at the dealer, I just bring my Quantum Blue. There is a lot more to Aces IV than the Vpower has. I use Costco premium and Aces so cost per gallon is about the same (but 102 octane).
I haven't made any engine modifications. I tried an AEM intake but didn't like what it did to my oil test results so I removed it. I've only done a cat-back of my own design/build. You would have to test for yourself, but I'm really happy with how much quieter the engine is and how much better it responds. I haven't dynoed it or anything that would give a scientific comparison, but with my 60 years of car tinkering, I love the results. The oil test results really convinced me.
I will definitely try it, even if it is a one-time thing, just to experiment. My really only complaint about this car is the engine noise. If I can get around with the Quantum Blue and Aces, I will be very happy
Thank you for taking the time to explain these things
tl_luvva
1/2G MDX (2001-2013)
15
Jan 19, 2009 11:02 AM
buynewcar2003
May 2, 2002 08:34 AM
