Check VSA, Hill Start Asssit and Power Steering systems
2016 ILX with 61K miles. My gf hit a cement block in NYC on the front right and threw the front alignment totally out of whack. Took it to mechanic over the weekend to get an alignment and they diagnosed a bent tie rod. The tie rod was replaced and the alignment done. Car steers and drives fine. However, I am getting check VSA, check hill start assist and check power steering system warning lights. I told the mechanic that he must have done something because didnt have this issue prior. He said the repair he did wasnt electrical so it's not related. I'm at a loss as to what this is. Any thoughts? They tried resetting the errors and it came back on again. I will have to schedule an appointment at the acura dealer but wanted to get everyone's thoughts.
It is the fuse multi block that's either blown or not seating properly. Try replacing the fuse block and reseating it again. Let me know if you need more technical details, I would be happy to explain more.
Big Jimmy (03-27-2022)
In any event, I'm interested in trying your suggestion. Which fuse needs to be replaced? If you can provide more technical details, I would appreciate it!
Hello All. The issue was fixed and I wanted to report back for the benefit of others. To recap, I had front tie rod replaced and front alignment performed on 2016 Ilx. Shortly after the VSA, Power Steering and Hill Assist warning lights came on.
Took it to dealer who claimed it was a defective steering angle sensor and quoted $500+ for parts and labor. I declined the job. I did extensive researched and learned that most likely the steering angle sensor had to be reset/recalibrated. I purchased a scan tool with HDS software preloaded from Amazon (Foxwell NT510 Elite -$179.99). Subsequently, I did a system check with the scan tool and reset all the fault codes. Then i reset steering angle sensor and performed a neutral position memorization procedure. All is fine now and warning lights are gone. I can't believe dealer claimed it was a defective sensor and wanted to replace the part. Hope this helps.
hi! i know this post was made a little while ago but, i have pretty much the same issue exept the fact that my abs comes on as well, can you talk me trough the process of how you found out that that tool was the right one for your issue? i do not have the money to spend on an expensive tool like this and not being sure it will be the right fit for me,
Thank you for your help!
I'm having the same issue. Ive checked the fuse, its not blown and the part is 1350.00. I ordered thr part from an acura warehouse, the order was canceled in early July because the part was on backorder until mid Aug. Where is this part located in case i can change myself.
every situation is different, so you really cant just quote a person...you actually need to tell us what part you need.
justnspace (08-27-2021)
6th Gear
Having same issue on my 16 ilx ,check brake light, check abs light, check vsa light , check power steering light and hill assist light. The warnings come on while I'm driving and stay on for for about an hour then they go away for about a week now they're coming on more often like every other day.
. I noticed that if I park the ilx with the warning lights on then like an hour later when I gotta go somewhere I turn on the car the warning lights will be on but as I'm leaving and turn the wheels I hear a noise coming from the front wheels. It's like something getting snagged grinding type noise or something engaging or disengaging and as soon as I hear the noise a few seconds later all the warning lights turn off.
I have an extended warranty that's about expire in two months . I have an obd scan tool and no codes pop up . I took it to the dealer but they said if no codes they can't help me and would charge me just tell me what I already know that there's no codes. Any help would be appreciated.
DaIll1 (05-28-2022)
A couple months later in rolled all the same problems and now my dash is lit up like a Christmas tree including check engine. My husband unfortunately was recently diagnosed with an enlarged heart/heart failure and went into surgery for a pace maker. I’m between all the crazyness we had our first child. Needless to say as important as our only car is we’ve had to put it on the back burner. With my husband unable to work and me being out of work for years I simply do not make enough to even begin working out all the problems my poor car has suffered threw and going unfixed for so long just adding more problems to the mix.
Acura zine truly is a blessing to all of us and so are all the people that take the time to post their problem and solution. It gives everyone somewhere to start. Unfortunately very very few mechanics can be trusted these days so like myself and I’m sure many others have to become their own mechanic. Couldn’t have done it without the Acura zine family.
So please anymore updates or similar experiences please keep them rolling! You guys are life savers for us are our acuras!
PTN
07-01-2012 04:27 PM
Bladehunter
12-01-2004 10:17 AM
