Remove tail lights ILX 2016?
Old 09-15-2016, 01:33 PM
voodoo411's Avatar
I want to paint my tail lights. I tried to remove the trunk tail light portions which have reverse lights, but couldn't do it. I removed some bolts but it's still attached somehow. Any tips?
Old 11-28-2016, 06:48 PM
Chrifff's Avatar
I am sorry for the delay on a response, I have not checked the forums in a bit. I have a 2013 ILX however the rear lights fit essentially the same way - It is probable that your issue is just clips, try pulling straight out and the tail light should come out.
Old 12-08-2016, 01:28 AM
iRaw's Avatar
What color do you plan to paint the tail lights? I've found that most paint ends up looking dull and matte color after a while.
Have you considered a Lamin-x Film? I was tired of the Red/Clear look of my taillights and went with a All Red Laminx Film. It's a nice glossy film. Looks factory OEM once installed. Best part is, I didn't have to remove the taillights to apply the film.
I think it turned out pretty good.
BEFORE:
AFTER:
Old 12-08-2016, 06:59 PM
oxidez's Avatar
This might be a stupid question but, is your rear turn signal light now red? Or is it like a pinkish color cause of amber light and the red tint.
So, if I do this, would I need to change the amber bulb to achieve a red turn signal.
Old 12-09-2016, 03:21 AM
iRaw's Avatar
Good question, I was worried about this myself. I thought I would have to change out the bulbs to Red Bulbs. But in fact, the Red Film is so thick it makes the Turn signal completely Red as well. No amber/pink tint whats so ever.
It doesn't sound like a simple film would be strong enough to turn a yellow light completely red, but it is. No bulb changes needed
I'll see if I can take a picture with the signals on.
Old 01-16-2017, 05:52 PM
idelgado782's Avatar
The red does look good. I was thinking of doing this myself and even looked into laminx. Were they hard to install?
I am torn between the all red and smoked out
Old 01-16-2017, 06:52 PM
voodoo411's Avatar
I ended up painting the 2016 tail lights without removing the trunk portions. 4 coats of red night shade, wet sand, 4 coats of clear, wet sand, buff, polish.
the result is amazing.
I changed the signal bulbs to red LED 7443 dual filaments. Tap 3rd wire to running light.
And the video
Old 01-17-2017, 07:54 AM
That red does look good!! Youre car looks great and the emblems are 👌🏼! I might steal that look! I was on the fence because I don't like how tinting can have that dull finish. And the smoke look that I want, I can't really get. Here's a photoshop rendition of how I would want it:
But it the way you did your is legit! Also you get extra kudos for doing it yourself. I'm not that skilled nor do I have a garage.
Old 01-17-2017, 10:05 AM
voodoo411's Avatar
i like your rendition. I tried smoked vinyl b4. It didnt look good on the clear part of the tail light. Now i see your rendition, its the way to tint the 2016 tail light.
After seeing how bad it looks smoked tinting over clear lense. My plan was red out then smoke all with night shade. Right now I enjoy the red out tail light, when summer comes, ill put on some smoked night shade.
EE4Life
ILX
03-27-2024 10:51 AM
chillingrsx
ILX
69
08-01-2016 04:26 PM
MasterDavid
06-15-2016 10:09 PM
skwrl10r
04-08-2016 07:29 PM
EE4Life
09-11-2015 10:13 PM
Quick Reply: Remove tail lights ILX 2016?
