Rear LED turnsignals
Hi there-
I'm new to the forum. I just purchased a 2016 CPO ILX Technology Plus with ASpec. I love the car and already ordered Morimoto projector foglights in 5000k, I swapped out my rear license plate lights to VLED 5000k's. I'm also going to swap out my trunk light to a 5000k LED, my reverse lights to 5000k and I'm also swapping out my front side marker lights to much bright amber led's.
My only question is the rear turn signals. I'm not sure why Acura decided to cheap out on the rear ones considering the fronts are LED. Anyway does anyone know if an LED load resistor is required when swapping out the rears for LED?
more likely than not, yes. Try it. If it hyper blinks, yes.
You will need either an electronic flasher or resistors to prevent hyper flash.
BT3
11-21-2007 05:59 PM
