List your Problems/Issues with the ILX
#121
my rear view camera and trunk release came loose! i noticed it when i wanted to open my trunk via the trunk release and felt it move, and sure enough the whole piece was loose.
I am 100% convinced my car was made at 5pm on a friday
#122
mine is brutal in the rain. when it is sitting out side for the day and it rains, there is a clunking sound from the front as if the calipers are not getting "unstuck" for the first 10 stops.
Same here.
Got my ILX end of March, just over 1k miles now.
20% of the time after being parked over 6-8 hours, the brake pedal is pretty hard like it would only press down 1/4 inch or so.
Please let me know what the dealer says on your case.
Hey what yr is ur RDX? I got a '13 RDX.
#123
I wonder if the rear hardware come loose due to the harsher ride in the rear...
#124
Same here.
#125
I've got a 2014 ILX base. After sitting in the garage a week, the brake pedal is hard. After 2 weeks the brake pedal is rock hard. It's difficult to start the car in this condition.
Purchased the car in Nov and have VIN 10500 approx. Only about 900 mi on car now.
I think it's the brake check valve or the brake booster. Will take it to Acura when I have the RDX oil change in the next few months.
#126
I have researched the issue and it's either the check valve or the brake booster. Te dealership tech should be able to do a test to determine which one is at fault.
With your issue being more frequent, the dealer should find the issue quickly.
Please post what they find.
#127
I'm taking the RDX in for an oil change in June so not yet.
#128
Hey everyone I just joined I was on ilx forums before
2013 ilx 2.0 tech
The issue I noticed with mine is the chrome piece on the right side of the car is starting to fade. I haven't made a big deal yet, but do you guys know of it's covered under warranty?
2013 ilx 2.0 tech
#129
I'm pretty sure it is, depending on your mileage. I don't know if you bought preowned. I would check thats its not just stained by something. Can you please describe where exactly the chrome is fading? I ask this because if for some reason they don't do something about it, you may be able to cover it up anyway with some window visors. I've been test fitted already for window visors. If its along the top curve of the chrome, then it would be covered up anyway, and would have new chrome over it.
#130
It's small but noticeable if you know about it.
#132
i dunno I think they might give you the runaround because its really small - plus they might try to say you did it... but if it bugs you a lot, try to go for it. I don't think you can fix that other then replacement...
#133
I'll go to the honda dealership near my work and see what they say, if they say something positive, i'll drive to acura. i'll keep you all updated!
#134
cool good luck man
#135
My hill assist makes a funky sound every now and then don't know how to describe it but it sounds like a grinding or rubbing sound??? Maybe brake still applied and holding when I try and start driving?
Never had it happen in my WRX and it had hill assist to, but seemed better than the hill assist on the ilx
#136
Not really a problem with the car, but the Acura Keyfob has worn down horribly. Just over 1 year of ownership, and almost all of the silver paint on my key fob has scratched off. Anyone know if the dealership will say its wear and tear or if they would replace it under warranty?
#137
Doubt it. Key fob cover purchase is in your near future... I can see it my crystal ball... oohhhhh ahhhhh... so nice it looks in the future.... wrapped in the leather or the silicone... kinky no?
#138
My rear suspension has been making a clunk sound for about 8 months now... sadly, I never took it to Acura when I first noticed it. About 3 months ago, someone made a huge dent in my rear driver side section of the car just in front of the tail light and rear bumper. I took it to Acura last month, and they found out my car had been damaged and the underbody spray or whatever wasn't 'from the factory'. Because of that, they wouldn't replace my suspension. The service advisor knew something though, as if this was a common issue with the ILX, but was apologetic that he couldn't do anything due to the damage being so close to the rear suspension.
So... I am thinking of just replacing my whole suspension setup with new struts or shocks, whatever our car uses.
#139
On another note, I have some problems that I've been having and wanted to see if anyone else has these problems and if they are something I should bring to the attention of my dealership
-The arrow that represents the car on the navigation is occasionally very off (Says I'm ~1/4 miles to the right or to the left of where I actually am). Once it had me driving straight through neighborhoods and rivers and such when I was on the highway
-The rear center armrest has come loose/off. I have been able to put it back in place, but it keeps popping out and recently a plastic clip part came off where the armrest attaches to the seat back (planning on bringing this up with the dealer)
-The passenger seat recline does not work properly - The seat goes down fine, but you need to pull it up for it to come up
-The rear bumper has popped off on the left side. Admittedly, I don't know when this happened or if it was before delivery or after. Looks like a clip broke or something?
#140
^^ What you have is the classic result of stupid reactive dampers by Sachs...they are causing problems for ILX and RDX owners alike.
They can be swapped for Civic rear shocks and that should solve your problem and make your car quiet again.....Don't hold your breat for Acura to solve this issue for you
#141
Push button start does not always start car the first time in the ILX 6-speed. Several error messages have been seen, but nothing is recorded as an error in the onboard computer. Acura bought back my 2013 for this issue and the 2014 has the same problem.
#142
Ctnyc all the issues you listed should be brought to your dealerships attention. All small issues they should fix under warranty unless they claim you hit something to make the bumper clip break.
The longer you wait the less likely they'll fix these issues... but those are simple issues many new cars face. I'd consider it an end of the week build and maybe they didn't take enough time on the production line. But not an issue with a design flaw
As for jb3stix. I find it hard to believe both the 2013 and 2014 Ilx had the same push button issue when no one else is having it.
No disrespect meant but at my work if one person cant properly operate 2 fire arms it's not the guns fault it's operator error.
What are these warning screens you see? What do they say?
When you go to your car do you sit down and wait one second. Then press the brake firmly and wait one second then press and hold the button for a second.
With push button starts I often see people just in a hurry. They don't press the button firm enough or don't hold the pedal down long enough so the car doesn't turn over or goes into accessory mode.
#143
^^ I agree that sometime, people don't depress the pedal far enough. With the RDX and ILX, I find the brake pedal seems to lose the air and feels very hard so you have to press that much harder on it....maybe that could be the issue
#144
When you say "Acura bought back my 2013" ILX, how many miles were on it, and did the dealership buy it back or corporate?
#145
Hey hondeducation - Can you provide more details on the clunk noise that you are talking about? What are the symptoms? My ILX Hybrid does make some pretty loud "clunk" noises when one of the rear tires hits a pot hole. Was like this since new - Always wondered, but this is the smallest car I've owned so I just thought that it was normal...
#146
mine used to make the thump like something was loose in the back over large potholes, but now it's an everyday thing even over the slightest of bumps. it's very annoying and sounds like a cheap old car. i wonder if pedestrians on the street can hear it when i drive by them...
I have a laundry list of problems I'm bringing up at my next service... I better get a loaner car because I'm not waiting there for hours on end
On a similar note, I have a question to all you ILX'ers. If you park your car outside in the rain, when you drive off, do you hear a very loud running water noise? Can't pinpoint where it's coming from but it happened the last 2 times it rained, and it is very very loud (I can hear it over the music) Any ideas what this problem might be?
#147
I'm not sure about that problem, but a 15 year old Buick we had in the family had a shock that creaked/thumped every time it moved the slightest bit... Then again, that car was the definition of a beater. I would get your car checked out by the dealership as well.
#148
Wow... I was hoping it was only my car... I'll bring it up with the dealership though and hope for the best... Even a base Elantra doesn't have half the problems I've had with the build quality of the ILX
#149
The issues you 2 are facing does not... and I repeat..DOES NOT reflect the over all build quality of the ilx.
All cars will have lemon cars and all cars will have those Friday 5th builds.
We have hundreds of ilx owners. Half of us flock here because we like to mod our cars the other half are looking to fix issues.
So you are going to see a number of enthusiasts and a number of people with issues.... little in between though but keep in mind there are far more ilx owners with no issues not on this sit than people with issues.
I would highly recommend not waiting until your next service as this makes the issues seem petty if you can put them off.
Demand the car is not to par. You bought a car without "...explain issue..." and take it from there. If they won't trade the car in its your dealer that sucks not acura or the ilx as a whole.
robtroxel (06-05-2014)
#150
usdmJON (06-07-2014)
#151
Good luck. Dont let the stealerships manhandle you.
Demand the car wasn't like this when you purchased and you demand under warranty the car be brought to the state you purchased it at.
#152
Wow - I feel like a troll for reporting yet another problem with my 2013 ILX Hybrid with 25k miles on it. Now it is becoming clearer and clearer to me that I have a lemon car
I went to my local Honda dealership today to get my oil changed (On a whim while passing by since they are cheaper & have express service + it's the same auto group as my Acura dealership) When they were checking the fluids on my car, they called me out to the garage and showed me the brake fluid reservoir. Almost bone dry. Since they are in the same group as my Acura dealership, they talked to each other and determined to finish the oil change at honda, fill up the brake fluid to max, and then drive to the Acura dealership and get the brake fluid looked at plus all my warranty work.
Honda dealership said that there was no evidence of a leak and that it is very very odd. My Acura dealer service manager literally couldn't believe it and asked really or what several times. I only got my car serviced as these two dealerships within the same automotive group, and have had my Honda serviced with them for years as well and I trust them. So for now I'm in a FWD TL Special Edition loaner (Kind of upset that there is no navi on the loaner, but I'll survive). Going to call tmrw and ask them to also give me a trade in offer on the ILX as well to see if it makes financial sense to buy a new 2013 left over ILX or TL
#153
It is odd. Good luck.
#155
2014 ILX Tech.
well, just got back from road trip. Dallas to Branson Mo. got good gas mileage. with all the mountains up and down, up and down, etc. still managed 34.2 mpg.
my problem though is, every time we went up a mountain, it smelled like exhaust, wife was getting a headache. but only on the ups. going down or level, no problem at all.
and it sure could use lumbar support.
#156
And AMEN! on the seat needing better lumbar support.
#159
Clutch Issue?
Hi! New to this forum and really new 2014 ILX 2.4MT owner.
Here's my problem and hopefully someone can give some thoughts as fast as possible.
My new 2014 ILX (805 miles, yes under 1K) is at the dealer service for the past 4 days because of a noise/grinding in clutch when upshift. No, not the clicking when depress the clutch as others have mentioned. An actual grinding/vibration noise in the clutch (not the stick) when depress to shift to a higher gear. It does not happen when the car is "cold" (1st 5-10 minutes of car running the sound is not heard) and does not happen when downshift/have foot on the brake.
After hearing and acknowledging the issue, the dealer/service manager has now "rebuilt" (replaced) my clutch and the issue has not resolved. Now they're telling me that they've gone into their inventory and that the 2015s also make the same noise, so this is "normal."
Is it normal? I've driven MT for 24 years (Toyota, Saturn, VW---btw loved the Saturn) and have never had this with any of my other cars.
I love my ILX otherwise, but this doesn't seem right to me.
#160
ElfFisch (10-09-2014)
