2013 ILX Fuel Injector
Old Jun 16, 2017 | 05:21 PM
Zubair Khatarwala's Avatar
My car is 2013 ILX Hybrid with 70K miles. is this the time I should get Fuel Injector & Carb cleaned? I am noticing bit low pick up on my car. it is 4 cylinder engine 1.5
Old Jun 16, 2017 | 06:07 PM
No. Premium fuel has cleaners and detergents in it. That's all you have to do to keep your injectors happy. Fill it with premium fuel
Old Jun 20, 2017 | 10:45 AM
Chrifff's Avatar
Justnspace, is right.... If you usually don't use premium fuel you can try a cleaner additive and then use premium fuel occasionally. Also this generation is not direct injection, hence keep the ilx in a lower gear and let the rev's hang higher a bit to help burn off anything on the carbs (if there is anything).
