14 ILX 6 SPD While Downshifting Has Water Rushing Sound in Glove Box Area
My ILX was making a water rushing sound when letting off gas while IN GEAR. Or if I'm outright downshifting into breaking situations or turns. If I move the stick to Neutral the rushing sound would virtually disappear immediately. Acura shop thought it was clogged AC lines when I first reported it. Claimed it was fixed but sound never went away and sometimes it is really loud coming from glove compartment area. As I remember this started happening after a tranny flush at 30K miles but never put two and two together till now. Now back at the shop for 4 days and the Acura Mechanic hears the sound (thankfully) but still unable to fix. They are keeping the car for now. Anyone else have this issue? I've searched everywhere and found nothing.
I've had the issue on my '13. I also had a transmission fluid change, around 37.5k miles. I'm not sure if the noise appeared before then or since. Anyways, I'm now at 65k miles and I get that sound occasionally and have just ignored it. Please update if you find out the cause.
Just did a google search not specific to our car about water sloshing sounds and it seems as if the most popular cause is being low on coolant. There are a few other possibilities (including clogged AC lines), of course.
how are your fluid levels
Thanks for looking. It's pretty bad in my car...my kids always call it the water car. :-) It's definately every day, the only difference is the extent of the noise and amount of water rushing sound, sometimes a little and sometimes a lot.
The only thing I've nailed down is the immediate stop as soon as I take the shifter into Neutral. So is there like some sort of "sending unit" while downshifting that sends fluid? I'll keep you up to date as soon as they find it. It's been a week tomorrow. Nice loaner though...a '16 TLX |
(Post 15969435)
I never went under and pulled the tranny plug though but I'm assuming they did this at the Acura Dealer after I mentioned all of the above details. The service rep called me a few times to keep me up to date and mentioned the Tech bleeding this, that, and the other thing, but with no success. Crazy. I'm just glad the tech actually understands it's not the AC lines because sometimes these dealers make you think you're crazy and push you away. |
Update a Few Weeks Later...So car is still in shop. Went from bleeding all systems, replacing the heater core, all gaskets, and now after an engineer from Acura visited the shop and decided it needs a new top half of the engine. So all new head going in this week. Not sure if that will solve the water sound but we'll see.
:what:
yay i guess! |
Originally Posted by rocket354
(Post 15969433)
I haven't heard the sound since, so hopefully it's really fixed. But I do have to say, Acura service is much better than any service I've gotten anywhere else. |
I've heard gushing water sounds in my 2013 ILX 6-speed since the day it was new. Sometimes sounds like the passenger door is full of water. Hasn't presented any issues though. 194,000 miles and still trouble free. Just had to replace the starter for the first time.
Originally Posted by 4cruizn
(Post 16001429)
Mine was the second one (air in the coolant system) and since it's been fixed not only has the water noise gone away completely, but the engine is considerably less buzzy (still noticeable of course) and feels a bit more solid/stout. It really feels like brand new again. |
Not sure if this has been solved or not, but same exact issue, with identical symptoms, same exact car....Topped up coolant and the issue was resolved!
