RGB vs CMYK Output
Because Of You
RGB vs CMYK Output
Hi,
My DVD player has an option to select RGB or CMYK output. Just what is the difference in term of watching DVD on a TV?
Thanks!
Thanks!
The levels of video connections are from worst to best:
Coaxial - screw on connection
Composite - red, white, and yellow
S-Video - composite but video is the black connection with teeth
Component - red green blue for video and white and red for audio
HDMI - one single digital connection for both audio and video
I posted this because I'm not sure what the abbreviations for yours stand for.
Because Of You
I am sorry. I double check the selection. It is RGB output or Y/Cb/Cr output; not CMYK output.
It says:
"You can select the color space for HDMI output. Set the appropriate color space for your display device..."
"...when the connected device is not compatible with the Y/Cb/Cr, HDMI signal is output as RGB regardless of the setting."
So... what is different?
It says:
If your TV will accept the Y/Cb/Cr use that.
Y/Cb/Cr will eventually get converted to RGB by your TV. The easiest way I can explain why people use Y/Cb/Cr is that it plays nicer than RGB when sent over wire.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
