Panasonic PT-52LCX15b 52" LCD Rear HDTV
Is this TV any good?
Specs:
# Diagonal Screen Size (inches) 52
# Aspect Ratio :16:9 (Widescreen)
# Resolution (Pixels) :1280 x 720
# HDTV Compatibility 1 :480p/720p/1080i
# Anti-Glare Screen
# Digital Comb Filter :Motion-Adaptive 3D-Y/C
# Edge Correction :Horizontal/Vertical Edge Correction
# Progressive Cinema Scan (3/2 Pulldown)
# Brightness Level (cd/m2) :400
# Progressive Scan Doubler: (Enhanced)
# First Surface Glass Mirror
# Wideband Video Amplifier (HD Enhancer)
# Selectable 4:3 Scan Mode
# PC Display Capability :VGA, SVGA, XGA
# Noise Reduction - Luminance
# AUDIO
# Audio Output :30W (8 ohms, 70Hz - 16kHz, 10% THD)
# Artificial Intelligence Sound
# Bass/Treble/Balance Controls
# BBE® High Definition Sound : (BBE® ViVA HD3D Sound)
# Speakers :4
# Stereo/SAP with dbx® NR
# Surround Sound
# INPUT/OUTPUT:
# A/V Input Jacks :2 Rear, 1 Front
# S-Video Inputs :2 Rear, 1 Front
# Component Video Inputs :3
# RGB PC Inputs (D sub15) :1 front
# SD Memory Card Slot (Photo Viewer)
# UHF/VHF Inputs :1
# HDMI-HDCP Interface
# CableCARD Ready 2
# A/V Output Jacks (Program Out) :1
# OTHER
# Menu Language :English/Spanish/French
# 181-Channel NTSC Tuner
# Parental Guidance (Channel Lock and Game Guard)
# Picture-in-Picture Capability :Split Screen
# Remote Control :Lighted Disk Home Theater Deluxe Remote
# Sleep Timer
# Auto Shut Off
# V-Chip Program Lockout (US/Canada)
# Video Input Picture Memory : (Standard, Cinema, Vivid)
# Video Input Skip
# Built-In Tuners :NTSC (Standard analog broadcasts)
# ATSC/QAM (SDTV and HDTV broadcasts)
# Extra Wide Viewing Angle
# Built-In Closed Caption Decoder
# Dimensions (H x W x D) :35.2'' x 48.3'' x 17''
# Weight :82.9 lbs
Specs:
# Anti-Glare Screen
# AUDIO
# Speakers :4
# Surround Sound
# INPUT/OUTPUT:
# UHF/VHF Inputs :1
# CableCARD Ready 2
# OTHER
# Sleep Timer
# Auto Shut Off
# Video Input Skip
# Weight :82.9 lbs
I have to admit that I never looked at Panasonic unless it was for a plasma. Unless you're getting a good deal on it I'd look at the new 1080p Sammy DLPs or 1080p Sony XBR's....
I'm also not a big fan of rear projection LCDs. Too much artifacting and SDE for my taste (I returned a Sony 60" rear LCD for this reason last year). Make sure you see one in action before buying it. Specs can only tell you so much...
The Third Ball
Received 4,967 Likes
I wish Panasonic would get over 1280x720 and start releasing 1920x1080.....even their pro gear for the field is all 1280x720 even though they now have 1080 cameras....jeez.
Originally Posted by Acuraluvr
i also hate rear projection..... bi-annual bulb replacement, pretty bad viewing angle....
Originally Posted by brianlin87
Thanks JB. I'll be sure to take a look at Sammy/Sony's this weekend.
But I won't lie, I'm inclined to wait for the LED DLP Sammy's coming in July(?).
But yeah, I think the new Sammy's are due out this summer. If I remember correctly the first DLP with the LED light engine will be the 56".
BoricuaTL
04-08-2016 01:08 PM
09-17-2015 09:01 PM
