Nest Hello Doorbell
Nest Hello Doorbell
Does anyone have one of these? Thoughts/Reviews? I had to remove my door bell to mount my storm door and I have yet to put the doorbell back on. We would like to have one again and am thinking about a video one (Nest Hello or Ring) Any insight from you gurus would be great.
Interested too. I will probably end up with one or the other at the new place.
Azine Jabroni
The only thing that's a little weird is, while the power to your doorbell can recharge your battery, the battery will still occasionally drain in extreme temperatures. So, in the middle of the summer I'll get a "you have low battery" warning. Instead of charging the battery, though, I just ignored it and it charged over a couple of days.
Go Giants
I have it, Its good
Can either one be used with battery power only? Or do they require the standard doorbell chime power?
I believe the Nest requires the power from the chime. Ring can work on battery alone. I'm probably going to get the Nest just because the rest of my house runs on Google products and since Amazon bought Ring, that relationship will not go over well.
Azine Jabroni
Ring does not require a doorbell mechanism. You can just mount it in front of your house. Then, when someone comes up to your house your phone will make a chime noise and give you a live picture. Ring also sells a chime if you need it. Be warned, though: the battery takes a long time (like overnight to charge) . That being said, the battery should last like 3-6 months with normal usage.
iWhine S/C 6MT TL
Our home has a surveillance system with a hard wired alarm system. I recently purchased and install the Ring Alarm system. In my package I have 2x keypads, 30x window / door sensors , the basic alarm kit, 4x motion sensors, 2 exterior flood light w/cameras, 1x door bell and an amazon wifi extender. The system was pretty easy to setup and install. I had a little bit of an issue with adding things or configuring stuff on the app. Once in a while it says reconnecting to base station and that it's running off of cellular power. Customer service says this is normal.. I'm waiting for the interior cameras to come so I can finish the system. Overall, I would say it was worth the money. It can get annoying on the app end because any movement is picked up and is sent to your phone "MOTION DETECTED" blah blah.. Neat thing, I can control everything right from my cell phone. I can see what sensor is tripped, where there's motion in the house ect. I do have two animals (Dog and a cat) the system is aware of "Pets" so it doesn't pick them up as movement, not too sure if it just disables the motion sensor "Shrugs". I did do a lot of research on the other similar systems, but felt more comfortable with Ring. Another neat thing on the app, it alerts you on anything crime related in or near your area. Today, a few blocks away from our home, someone had their vehicles vandalized and it was picked up by his ring system. He posted it on the app so others can see. I upgraded one exterior camera to a high def, motion detect, zoom camera. Unfortunately, there's been some crap happening in my town and it seems like the Police Department are lazy to do anything. I didn't want to chance anything which is why I invested to protect my property and family.
The following 4 users liked this post by 04WDPSeDaN:
04WDPSeDaN (10-19-2018)
Azine Jabroni
Azine Jabroni
I have Ring. It's pretty great. It's easy to set up and install, too.
Sounds like just a weak transformer issue. You can always upgrade it on the other end.
iWhine S/C 6MT TL
Anytime brotha! Sad world we live in today. To protect your family and property is priority number 1. I would highly suggest a wifi extender. This is the one I purchased from Amazon and it bridges the gap between my router to the base station to all the devices the base station connects to. Also, incredibly easy to sync with the router.
If it doesn't load, its call VICTONY WiFi Range Extender 1200Mbps WiFi Signal Booster with Hign Performace External Antennas WiFi Extender for 2.4G and 5G Frequency
Ring has a wifi extender / chime module as well
https://smile.amazon.com/Ring-Indoor...-no-redirect=1
I use it to extend wifi for the door bell. i THINK it should work with their security system as well?
iWhine S/C 6MT TL
Azine Jabroni
My Ring setup came with the same items.. however, for my size home, it barely picked up the exterior flood lights because the wifi wasn't strong. I have Verizon Fios with a powerful router, but it wasn't strong enough. I needed to order the wifi extender which works great now. Each exterior food light is running at RSSI-46 vs the 71-74 range. The higher the number = less likely for the device to function correctly and stay connected.
Just do nothing
Move to a better neighborhood. The Chime Pro works perfectly for me. Much better than before.
The Third Ball
Received 4,824 Likes
I have the Ring Pro which requires power. The regular Ring (I got my MIL one) can run off battery or power. For battery, if your door faces sunlight, there is a solar charger available.
Needs more Lemon Pledge
With the Ring app, can you have different devices all receiving the live feed and notifications at the same time?
I want to get this, and want to probably put a "living room" tablet on the coffee table with the app but have my phone set up with it too, for when I am not at home.
How easy is ot to control which device gets the alerts and when? Can you set up schedules that control which device will get the alert?
iWhine S/C 6MT TL
Here's the biggest difference from my hardwired system. My hardwired system has a massive DVR box which records and stores live feed for a little over 4 months. I can control everything from my phone like I can with ring. The difference is, ring picks up movement and notifies you, my system doesn't do this. I did get a new IR speed dome camera from Hikvision to zoom and record all movement in my driveway. The biggest issue I have is my driveway. I have a long driveway and my house sits far from the street. RING and my security cameras don't have a clear vision of anyone entering my property from the street. Each system has their pros and cons, RING is great for what it is. I'm still learning things along the way. Customer service has been outstanding with helping understanding or setting up stuff.
The Third Ball
The Third Ball
The Third Ball
Believe it or not the camera footage helps police. They also set up “neighborhoods” in the app where you can set off alerts to anyone living in the area to occurrences such as recent theft, attempt, etc.
Sorry, maybe I asked my question backwards. Can I have the live feed from the doorbell (say, when someone rings the doorbell) showing on more than one cell phone/tablet at the same time? One camera feed, multiple monitors?
stogie1020 (11-01-2018)
But I am not the best person to test this out because I have a Nest Hello (I like Nest products, have been using thermo for years) but then my smart home integration is with Amazon Echo. If I had Google Home instead for example, I could send the Hello's feed to any Chromecasted TV.
Can we rename this to the doorbell thread. I just got a Ring 2 and an extender with that Costco deal of a free year of DVR. The DVR feature is nice especially if you have crappy 25mb U-Verse internet as it's slow to load the video. My porch is like 4 steps up but luckily it comes with a 5 degree vertical mount to point it down as well as a sideways "corner" mount which you can stack together. The corner mount helped as I have frosted glass blocks next to my door, so without the mount, it's harder to see who's coming into the door. I don't have a hammer drill so my regular drill struggled with the holes for the mounts and unfortunately it's not 1000% flush but it's in good. The extender continually disconnects because of my crappy wifi. As a reminder, Ring 2 wireless only supports a 2.4Ghz network. The app UI was a little quirky and the settings limited but I got it down now. If I get a motion alert, I'm better off snoozing and waiting for it to fully download because it'll take a good 20 seconds to open after unlocking my phone so I'll miss who came by. The picture is clear and at night you can identify people. The width of the camera is pretty good too. I thought I wouldn't be able to see my driveway but surprisingly I can. For $200, kinda meh which is why I caught it on a pre-BF deal.
Are you sure your Ring 2 came with an extender? The Chime (not Pro) is simply a wifi-connected 'speaker/bell' and not the extender. Only the Chime Pro is a true extender (it comes with two antenna on it). The Chime Pro came with the Ring Floodlight at Costco, whereas the Chime came with the Ring Doorbell 2 and Pro.
In other words, shitty wifi, you need the Chime Pro. The Chime Pro sits right between my router and Ring 2 and really helped the connection. I have the Chime in the rear of the house and connected all of them so that when someone rings, both Chimes will.. well, chime.
Yeah you're right. No worries since we don't get a lot of visitors to ring the bell. Plus my router is like 15 feet away from the Ring. Shit if it's taking up network space, I should just unplug that bitch.
JdmJ32A
08-09-2012 08:41 PM
