How to Remove Tumbled Marble Backsplash?
How do I remove tumbled marble backsplash in my kitchen? It appears that the marble itself on the sides is filled with grout, but not sure what the person used to have it glued to the drywall. I put a putty knife behind and tried to push it off but it wasnt working well. Any advice?
The sizzle in the Steak
It's not much different than any other tile back splash removal.
http://www.ehow.com/how_4869098_remo...#ixzz2bE7h7nLk
Read more: http://www.ehow.com/how_4869098_remo...#ixzz2bE7czt00
Instructions
Use your grout remover to file away the grout around a single tile. File as deep as you can. You can also use a rotary tool, such as a Dremmel, or a drill with a grout removing bit. Wear safety glasses and a dust mask when removing grout manually or with power tools.
Use your ceramic chisel and hammer to chisel a crack into the center of the tile. Then chisel the pieces away so that you can reach the edges of the other tiles.
Use your small, flat crowbar or spackling knife to reach between the tile and the drywall. Hammer it into the space behind the tile, creating a gap between it and the drywall. With luck, the tile will come off easily and in one piece.
Continue to use the crowbar and hammer until all the desired tiles are removed. If the drywall is still intact, then this is good. If not, the drywall surface must be patched or replaced, especially if there's water damage.
Use your spackling knife to scrape away the old adhesive. Use the spackling knife to also mix a little plaster of Paris into the joint compound, and then patch and smooth any minor indentations or holes. Let dry.
Sand smooth the scraped, patched and dried wall. You can either paint it or put new tile on the wall.
97BlackAckCL (08-07-2013)
Thanks, I got most of it off except for one part where I ripped the hole drywall out in about a 24"x24" space!!! So I need to replace the drywall there, but everywhere else came out well
Good show!
dainmezron
10-16-2015 06:56 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
