cleaning hardwood floors?
Just got new hardwood floors with water-based finish.
What should I use for regular cleaning?
Just a microfiber cloth?
Is the roomba or scooba recommended?
Vaccuum cleaner?
Vaccuum cleaner?
Needs more Lemon Pledge
We have something similar, but when we really want to clean it, we use this
http://www.amazon.com/Bissell-1867-S.../dp/B00008NRTV
Pink things in...
I use something similar to stogie's suggestion [microfiber mop thing] and Bruce floor cleaning solution.
My cleaning ladies say they sometimes use some diluted vinegar to clean my floors.
Received 1,080 Likes
HOWEVER.... how was the floor put down?
1) unfinished flooring laid then a poly finish applied
2) prefinished hardwood
3) laminate (i.e. Pergo)
If it it #1, go to town with the vinegar/water mix
If 2 or 3, use a slightly damp mop (wring it out several times). Problem is the water can collect in the grooves of a tongue and groove floor and warp and rot the wood.
I asked my Dad's friend about it and he's personally seen delamination in laminate flooring from the use of both those steam cleaners as well as using a wet mop.
As many have said, sweep/vacuum floors regularly. Here's what we use, it's safe for pre-finished and site finished wood floors.
http://store.mybonahome.com/hardwood-floor-cleaner.aspx
Pink things in...
The Third Ball
Received 4,911 Likes
Go over it with a vacuum first and then we use Bona with a microfiber thingie on a stick.
The Third Ball
Thanks for all the replies.
I've got a microfiber mop. I don't have any solution to go with it yet, but I'll pick one up.
In regards to the type of floor: Its was an unfinished hardwood, with a water-based finish applied after it was installed.
So no one recommends a roomba? Are they not good for the floors, or just don't really help?
JDM96specCTR
10-17-2015 01:06 PM
bra, cleaner, clear, differentiate, floor, floors, groove, hardwood, laminate, prefinished, recommended, scooba, slinks, tongue, wood
