00TL-P3.2's New House
#123
Get the rest of that junk stored away in a shed. Question on the pool. Is it salt or chlorine? Also, what kind of decking is around the perimeter? Hard to tell from the pic. I signed the contract for a pool build a few weeks ago, just waiting on city approval to get started.
Our pool is chlorine. It's a pebble type 'decking' around the pool (similar-ish to the actual pool lining), with stone bordering the pool edges. It can be pretty rough on bare feet, but not terrible.
#124
Chapter Leader (Houston)
A 2nd shed (have 1 in the back for the pool stuff) is definitely going to happen eventually.
#125
https://www.infantswim.com/
#126
From what I've read, chlorine to salt conversion is only around $1k.
Most people I've talked to with salt say it's a lot lower maintenance. But, our pool has been pretty low maintenance as well.
#128
If you both aren't a member as yet be sure to join Pool School - TFP Home Page. Tonnes of great information on there. I like to think of it as the acurazine of pools.
#129
^ Thanks, will look into that.
#133
Received 3,657 Likes
#134
Have a Rubbermaid shed right now, has a ~3ft shelf in it & has all the pool chemicals & tools. It's got the pool pumps/filter on one side & a large window on the other, so a larger shed wouldn't fit there.
I've got room on the back wall of the garage where I could put one for my lawn equipment, which would free up some space in the 3rd garage bay.
The red square is the shed I have now, blue square is where I'd likely put a 2nd. Black is the kid's swingset/play structure we put up in Dec.
#136
My Saturday
#138
Didn't check the strand before hanging it...
svtmike (12-06-2018)
#140
One of these days...
#141
Posted in SWIEDT & forgot to here as well.
Finished up the lights on the house
[img]https://i.postimg.cc/66Vr9k9r/20181216-174731.jpg[/img]
#142
Wrapped up a project I'd been putting off for a while.
Took down this valence (?) that the prior owners had built/hung months ago with the intent of re-doing it.
Picked up a ton of old wood & recovered and extended it.
Also hung a gift my parents got us for Christmas. A friend of my dad's makes these (assuming with a wood CNC or something similar). Measures roughly 34" W/T.
#143
Nice!
Guessing the Texas is laser cut from the singing of the edges.
#145
This.
Also the tightness of the radii.
I plan on starting to make state shapes as soon as I can get back out in my garage. I've been itching to get the CNC up and running finally. That TX one looks awesome, especially in cedar...and I just so happen to have some cedar looking for a home this spring so I may try this out.
00TL-P3.2 (01-03-2019)
Mr. Maker (02-01-2019)
#149
rockstar143 (01-03-2019)
#150
Threw together a couple more window valences yesterday, nearly free, with wood I had around the house/garage.
Will probably do 1 more over the door to the back yard, which is just to the left off the edge of the photo.
#151
Woke up this morning to a chilly room.
Downstairs furnace isn't igniting. Throwing an error code of "Burner not igniting"
Googleing the model # returns nothing, and there's no mfg labels on the unit. What I have been able to find so far, is to pull the igniter & clean it with some fine sandpaper. But, without a diagram, I don't want to just start disassembling the furnace....
#152
Post a pic of your panel and I might be able to help.
Also, shouldn't you be running the AC? It can't be cold enough for heat down there...
#153
I'll have to check when I get home. Downstairs was 67* this morning, so chilly, but not unbearable.
Luckily, the upstairs unit is still working, so the kid's rooms are fine.
It's 51* right now & supposed to drop to 44* overnight. May as well cancel work tomorrow
#154
It's 51 right now? Crack the damn window, no need for a furnace lol. It's 68 in my house while I'm home all the time, 62 at night.
#157
Definitely test the furnace reset like Sam said. Odly gas pool heaters work the same way and I have had to do this exact test procedure to figure out the flame sensor on my parents pool heater went bad.
#158
Checked when I got home last night.
Cleaned the flame sensor, seemed ok & had no buildup on it. Pulled the igniter & it had some buildup between the elements (shorting itself out?), cleaned it up & we were back in business.
Woke up this morning to a 67* downstairs again, so I guess it was a temp fix.
Now to locate a replacement.
#160
This.
He recently got a band saw, that'll help with some cuts, but he does the intricate stuff by hand...
