Best Value for a Bodyfat/Weight Scale? Is Tanita BF680W any good?
Best D-Line in the NFL
Location: Gainesville, Fl for college, Palm Beach Gardens, Fl at Home
Found this product Tanita BF680W at amazon.com for like $45 shipped.
Tanita BF680W Duo Scale Plus Body Fat Monitor with Athletic Mode can monitor both body fat and body water percentages. This scale also features a daily calorie intake function that estimates how many calories should be consumed in a 24-hour period for a user to maintain current weight level, and a dual recall feature that compares both current weight and body fat readings to the previous readings.
It got good reviews from users on amazon...what do you guys think?
Not Asian
Originally Posted by ABreece
Bodyfat scales are worthless, they're far too inaccurate.
How the heck would a scale be able to read your body fat, just by standing on it? I've never understood why people buy them.
Originally Posted by phipark
A scale is only good for one thing, weight.
The problem is there are a lot of factors that affect how well your body transmits electricity, so the scales are typically way off, and rarely even consistant.
Go Giants
Originally Posted by Whiskers
I have that Tanita and my bodyfat % changes every time I get on it.
I don't care if the body fat % is spot on, i just want to see if its consistent on the scale and see how much im improving. How about the water weight part of it? Seems pretty cool
Originally Posted by Renegade
3 Reviewers seemed to really like it.
The % isn't even consistant. That's why it's worthless. The same problems would apply for the water weight part of it.
My Work is Done Here
1 Post
Have you personally used it?
Originally Posted by vtec187
Ummmmm,body fat ratio's are not supposed to be consistant. If your hydration level changes it affects the ratio of bf to lean mass in the body. Body fat should be averaged by a weeks results. These scales are not the most accurate, however if you measure at the same time of day every day it will give you a good idea when you lose or gain bf. I just re read your post. If you mean consistant by different % for different times of day, then what I said stands. If you mean not consistant by diff readings right after one another I would have to disagree. I have one and if I weight myself 5 times right after one another it's always within .2 if it changes at all.
If you really want to dump the $50 on the scale, go ahead. If I thought it gave consistant results I'd buy one myself - being able to measure bodyfat changes that easily would be awesome. But I suggest you take that money and buy a camera and a mirror. That's the best way to gauge progress.
Go Giants
^^ I can get on mine and it will give me one %, step off and get back on with a different %. I hope I didn't gain any body fat in 10 seconds....
This specific model? No. But they all work the same way.
They are not accurate, they are not consistant - even if you measure once a day at the same time and average the results. That helps keep things more consistant, but even then they are not consistant enough in my opinion. A change in moisture on your skin, or extra salt in your diet, or any number of other factors affects the results.
I have this exact model and it was well worth the money. Tanita is the best for body fat scales, so i've heard. I don't really go by the bodyfat percentage, rather i use it to track my percentage lost. It's most effective in the morning, but not after a workout.
Pegon95
09-15-2015 01:54 PM
