% body fat device?
% body fat device?
Anyone know a good device to use to calculate % body fat? There's the tape, and the pinch tool, but I can't see how those are acurate. I remember in highschool the nurse use to put a device up to our biceps to calculate the % bf, but don't remember what it was or how much it would cost.
minibike wheelie king ;-)
Actually, I found that the caliper (pinchers) are more accurate then the electronic ones. Althrough there is a certain technique to using the caliper so I would think that it is difficult to use on yourself.
body fat measurement tool/caliper
My Work is Done Here
1 Post
Go here: http://walking.about.com/cs/calories...fatmonitor.htm
I've found #5 (the handheld one) to be the best
Electronic ones are pure crap - at one point one my wife got told me I was 29% bf which is complete bullshit. The calipers are fine, assuming you take more than 2-3 measurements. Take 8-12 measurements to get a better reading.
Masshole
My gym has an Omron (#5 from the list) which I've found to be reasonably accurate. Even so, I usually take 2 readings in a row just to be sure one isn't way off from the other.
FYI - Amazon.com sells them for $38
Kenpachi Teichou
I have a scale which reads out your % bf. It's a bit pricey but I needed a scale so I figured what the hell! Check it out
http://www.amazon.com/exec/obidos/tg...s=hpc&n=507846
I have a handhled one that measures the electrical resistance when you hold it with both hands. Probably not very accurate, but I mostly use it to see if my body-fat percentage is dropping.
The best way to get your body fat % is to get an autopsy done on yourself.
The second best would be hyrdostatic.
Skin calipers are quite good but it's not easy to get it done properly...
GÜNnµ ¡Ï
Registered Abuser of VTEC
And good idea to take multiple measurements to damp out the error.
Yeehaw
The electrical ones are good if you want to measure progress/fat loss. They may not be exactly accurate, but they will be fairly consistent over time. Plus they only take a couple seconds to use.
The calipers are good but you really need to know what you are doing, and take multiple measurements...
The Box
I had to bring this thread back
Does anyone know a good tool?
I just did 2 diff test.
TEST ONE (link)
Got 17.5%
TEST TWO (link)
Got 29%
Seems like there is too much of a difference here. Anyone have any insight where I could get a little more accurate answer?
TEST ONE (link)
Got 17.5%
TEST TWO (link)
Got 29%
BMI is a sorry excuse of body fat %
1st link gave me 7.5%
2nd link gave me 24.1
Pisses me off when they say BMI is you body fat, what terrible mis-representation.
Ive never done hydrostatic or bodpod BF% measurements (the only 2 i would trust), but I know im for sure under 10% so id say the first link is relatively close
Moderator Alumnus
TEST ONE (link)
Got 17.5%
TEST TWO (link)
Got 29%
TEST ONE (link)
Got 17.5%
TEST TWO (link)
Got 29%
Above n Beyond
Most BF percentage tests they sell are inaccurate out there. Unless you are submerged in water, the pinch test is the next best element.
If you're just throwing your height/weight onto an online program, you are wasting your time. $0.02
Yep, thread revival....
Cyber Monday deal at Buy.com: Omron HBF-516B Body Composition Monitor Scale, 45% off, $65 shipped.
C E R T I F I E D
personal trainer
This is very true. body calipers and a 7 point test site would be the most accurate other then doing a dexa scan.
MrHeeltoe
20
02-23-2023 01:54 PM
MetalGearTypeS
08-29-2016 08:28 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
