Will any brand engine air filter do ?
Old 02-20-2015 | 09:50 AM
SilverJ's Avatar
Just wondering. Outside of K&N(which I have decided against despite 6 extra HP ) they are all between 11-15 dollars. Am I good just popping anyone in there ?
Thinking of going with this one...
Amazon.com: Purolator A36308 Classic Air Filter: Automotive Amazon.com: Purolator A36308 Classic Air Filter: Automotive
Old 02-20-2015 | 09:52 AM
go for OEM.
however; if you want you can just go to autozone and pick up their brand of filter.
but honestly, this car is pretty much the same as your 3G.
anything you did to the 3G, you can do the same for your new 4G.
Old 02-20-2015 | 09:56 AM
SilverJ's Avatar
OK...got inpatient and ordered the purolator. I had a K&N in my 3G. Try something different. I thought I read somewhere that the OEM filters are outsourced and made by purolator anyway.
justnspace (02-20-2015)
Old 02-20-2015 | 10:00 AM
^you're most likely right.
and good choice on not going with the K&N.
Old 02-20-2015 | 10:27 AM
012TL-GLM's Avatar
I tried the K&N, no difference, I guess the only advantage is being able to clean it and re-use. FRAM is super cheap at my local farm & fleet, easy to swap out a new one every oil change, about once a year for me
Old 02-20-2015 | 10:31 AM
technically; with the bigger pleats of the K&N; smaller particles can be introduced into your engine.
Old 02-20-2015 | 02:50 PM
csmeance's Avatar
This one is fine to go with! OEM ones are 2 stage with a oil portion and paper section!
K&N can be good, however a lot of people tend to over oil them when reusing them and end up causing engine problems. IMO, the disposable ones are better.
Old 03-07-2015 | 12:10 PM
Marmbo's Avatar
Opened the air box last night to have a look at the filter for the first time since purchase and this is what I saw. I have already replaced the filter this morning but I'm curious what sort of look other people have with their engine air filters.Will any brand engine air filter do ?-9yvee10.jpg
Old 03-07-2015 | 04:16 PM
SilverJ's Avatar
Mine looked similarly disgusting. Check your cabin filter too, mine was gross.
I only have 12 thousand miles on mine too! Low mileage but my car is a 2012.
Old 03-07-2015 | 09:52 PM
Marmbo's Avatar
I checked and replaced my cabin filter in the first 24 hours of ownership, just took me longer to get around to the engine one. It wasn't nearly as bad but needed replacing as well.
Old 03-08-2015 | 12:17 AM
vtec260's Avatar
Had no problem running K&N during past four Honda/Acura vehicles. I clean and re-oil every 30K miles and good to go.
When it comes to any replacement parts, there always will be pro/con with each product, just like OEM oil filters made by Fram debate. Use whatever you feel comfortable and believe will get the best job done at good value.
02-25-2020 10:57 AM
HOWELLiNC
10-19-2015 04:26 PM
Abe_Froman
09-16-2015 02:27 PM
Aleax
09-09-2015 09:04 PM
bymotion
08-31-2015 06:00 PM
