Why all the engine shroud / cover?
Why did Acura cover so much of the engine bay with the plastic cover? In my mind that just begs for more overheating trouble as the air can't circulate as well. I'm sure the engineers have taken this into account, but who knows. The last TL I drove was spitting out TONS of heat from the engine. Doesn't make sense to me.
2G TLX-S
The engine bays of most upscale luxury vehicles are always covered up by some aesthetically-looking shroud covers to make it look neat, tidy, and expensive; whereas the exposed engine wires/hoses/ducts/pipes can be seen crisscrossing everywhere on cheap, econo vehicles.
a longitudinal engine layout looks a lot nicer
justnspace (06-21-2017)
2G TLX-S
Very much agree that a longitudinal engine layout looks nice, and a drive shaft to transfer power to the rear wheels even looks out of this world !
justnspace (06-22-2017)
The inconvenient truth
Longitudinal engines look better because its more symmetrical. Everyone loves symmetry, its the best.
This is a great thread as it got me thinking about heat retention. While the shroud dresses the engine compartment up, it has to hold a lot of heat around the engine. I took mine off today, I'm going to see if it makes any difference. I was wondering if it would make any difference on air intake. I don't think it's a Ram Air affair. I wonder how air intake will be affected, it seems that the volume of air available should increase.
marvinmartian (06-24-2017)
if you are concerned about heat,reroute the coolant throttle body line.
Honda routed coolant to the throttle body to prevent ice build up on throttle body plate, in cold climates.
however, in HOT climates, it just introduces warmer ambient temps to the throttle body... and we all know colder air is denser air
FYI; that's why the planes were grounded in Phoenix this past week. in order to fly, or create lift, the air needs to be pretty dense.
and hotter temps = less dense air = cant create lift
justnspace (06-24-2017)
Latent car nut
Received 2,005 Likes
I had a funny and very opposite experience years ago when I was doing departure stall training. We (my instructor and me) took off in a 1967 Cessna 172 with the venerable boxer-6 O-300 Continental engine on a day where the OAT was -21°F; I swear the 172 was off the ground before the IAS hit 30 mph (not knots). We headed to a mountainous area just west of the airport and started our stall training over a reservoir at about 2,000' MSL; full throttle, full back on the yolk, stall alarm, stall alarm..., buffeting, more stall alarm, the left wing finally dropped at about 28 mph. The thing was, before the wing dropped I noticed the mountains on either side of the reservoir were passing us; clearly we were flying into enough of a headwind we were literally flying backwards relative to the ground.
