Notices
Timing belts, which brand?
Old 04-11-2019, 12:52 AM
Registered Member
Anicra's Avatar
Besides actual OEM Honda/Acura Timing belt...Which brand is the best/favored if you cannot get OEM...Dayco, Gates, Koyo, Toho, Bando or Name a brand you had good luck with? I.E Which brand would you pick?
Anicra is offline
Old 04-11-2019, 01:06 AM
Registered Member
horseshoez's Avatar
In my guesstimation, the majority of folks around here suggest, if you're not buying the OEM kit, buy the Aisin kit (which comes with a Mitsuboshi belt):
horseshoez is online now
Old 04-11-2019, 01:16 AM
Registered Member
Anicra's Avatar
That is what I was leaning to. Thanks.
Anicra is offline
Old 04-13-2019, 01:27 PM
Registered Member
Why wouldn't you be able to use the OEM belt?
I went with the Aisin kit linked and used the belt included and everything went fine.
That said, the OEM belt is like $50. I almost considered tossing the belt that came with the Aisin kit and grabbing an OEM belt just for peace of mind.
alxhastngs is offline
Old 04-13-2019, 01:36 PM
Registered Member
horseshoez's Avatar
I have never heard any claim the belt which comes with the Aisin kit is anything less than the OEM belt. Have you?
Old 04-13-2019, 01:45 PM
Forum Contributor
EE4Life's Avatar
Received 1,117 Likes on 481 Posts
Honda/Acura part number 14400-RCA-A01 is manufactured by Gates Unitta.
Gates Unitta part number T329 is the same part without the Honda markings.
EE4Life is offline
Old 04-13-2019, 10:21 PM
Registered Member
Nope, literally just the fact that the OEM one lasted 105k miles with no issues so why not use the same one when you replace it.
That said, I bet on the one in the Aisin kit.
Old 04-13-2019, 10:40 PM
Registered Member
Reorge's Avatar
Gates, Dayco, Bando are brands I trust without hesitation for belts.
They are all available on RockAuto.com for less than $25.
Our 4G accessory belt is manufactured by Bando.
As mentioned by Horseshoez, I usually install the Aisin kit
Reorge is offline
Ninjak
First Generation CL Discussion (1997-1999)
09-11-2006 01:12 AM
Sflusa2004
Second Generation TL (1999-2003)
14
04-07-2005 08:42 PM
Sdog2012
01-05-2004 05:52 PM
JLK
First Generation TL (1996-1998)
05-28-2003 02:44 PM
Quick Reply: Timing belts, which brand?
