Timing belt replacement cost 4th gen
Wondering how much is a reasonable cost for timing belt/water pump replacement for 2012 Acura TL? Does it matter if I can OEM water pump or third party? Thanks!
That's a loaded and oft discussed question; search is your friend in this instance.
Cost is tough to say as it depends on where you live. But stick with OEM parts for sure when it comes to timing belt and water pump.
Buy the Aisin kit (TKH-002) off amazon. Less than $200 bucks for OEM parts w/o the OEM price.
As for install, call around. Anything over $400 is a rip off. :2cents: |
Use OEM or Aisin as mentioned above.
Acura dealers will charge around $1000-1200. Honda dealers will charge around $800. Indy will charge around $600. DIY should be $250 parts + beer if you are capable. |
Depending on location, you may find some local Azine guys who can do it or at least assist you if you don't feel comfortable doing it on your own.
Never knew about the Aisin kit. Huge!
This is timely as well for me too.
I can get the kit as well as the Bando OEM serpentine belt. My local shop quoted $500 for labor. Are these parts generally reliable? I also need to change spark plugs, which I can do myself. Is the NGK ILZKR7B11 (Gap 0.044") the right plug? Thanks in Advance. |
Originally Posted by tuxacura
(Post 16190618)
I can get the kit as well as the Bando OEM serpentine belt. My local shop quoted $500 for labor. Are these parts generally reliable? |
Just called a local Acura dealer for the cost of replacing the following:
Does this sound like a reasonable price? Thanks! |
If I don't do the spark plugs and the valve adjustment, it will be $13xx before the Costco coupon.
Geez. That's a lot.
If you were local I'd offer to do it for you at maybe $700 for all of it. It's 10 hours of work at best and about $250 in parts with spark plugs. |
Originally Posted by losiglow
(Post 16430720)
Geez. That's a lot.
A friend of mine at an Acura dealership told me he could get all the work done under three hours:
What about the front main seal and the cam seals?
Haha, I guess not. I don't even know what these are, and when they are supposed to be replaced.
Originally Posted by mrclemson
(Post 16432368)
(Post 16432321)
I could see 3 hours with a lift. It's unbelievable how much easier everything is when your not working on jack stands.
Yeah, he is a full time technician at the Acura dealership for years, so he's done at least a few hundreds of these if not more. The dealership allows their technicians to use the shop for their side work. I dropped off the car at 6:15 PM, he probably got everything done in two hours, because he showed up before 9 PM at my house which is a 35-40 min drive from the dealer.
Having done the timing belt and water pump etc in my CL, I would happily pay $1300 to have it done by someone else!
(Post 16190618)
I can get the kit as well as the Bando OEM serpentine belt. My local shop quoted $500 for labor. Are these parts generally reliable? I also need to change spark plugs, which I can do myself. Is the NGK ILZKR7B11 (Gap 0.044") the right plug? Thanks in Advance. As for the spark plugs, it depends if you have the 3.5 or 3.7. The 3.7 uses the single core - ILZKR7B11, but the 3.5 uses the dual core - DILZKR7A11G This is the case for the 12-14 (4G TLs). I've seen a lot of places online only selling the single core ones for the "2012 Acura TL", with no indication of the motor size, but after checking Acura/Honda OEM part sites, you'll find the difference between the two. |
When I had my 3G TL, I had the dealership do the belt/water pump service the first time, and it was $1100-ish, but they gave me a coupon that took 15% off so it was actually around $900. But, that was without spark plugs or valve check/adjust. I did it myself a second time when the car hit 200k and it took me about 6 hours of "actual working time", that's without all the breaks I took throughout the process.
I'm planning on doing it on my 4G within the next few weeks, but I'm really not looking forward to doing it cause it's the middle of the fricken summer and I live in Florida.... :explode: |
Originally Posted by mada51589
(Post 16436069)
A little late but....
(Post 16432321)
Originally Posted by teh CL
(Post 16432490)
(Post 16436120)
That's the exact thing I found out, after I purchased the ILZKR7B11. Even NGK's website states the ILZKR7B11 for the 3.5L. I had them in for a few weeks before I found out, after which I purchased the DILZKR7A11G's. I ended up putting the ILZKR7B11 is my wife's Pilot since they were specified for that engine. Never noticed a difference in the TL with the DILZKR7A11G's.
