Is there a DIY to clear headlights?
I've searched and searched and all I seem to come up with is people getting their headlights cleared by JNC.
Since I haven't received a response from JNC, thought I would give it a shot. All else fails, when he responds, I can just have him fix my fuck up.
Anyone can point me to a DIY step by step on how to open the headlights?
TIA
TIA
No, I don't believe one exists...
My old headlights required about 10-15 minutes in a 200 degree oven. After that the glue/sealant was soft enough that I could pull them apart. From that point on it's pretty self explanatory (as far as getting the guts apart).
Re-sealing involved re-baking them to soften the glue up again as well as adding more (RTV Sealant) and pushing together until all the tabs lined up. This part is really the most important IMO because even the smallest gap or hole will result in condensation inside.
I had issues with my old lights from time to time. I pulled them apart 3-4 times and dealt with condensation one of the times. In addition, I didn't use a high temp spray paint so it actually ended up bubbling from the FL heat. Due to these issues I'm very hesitant to mess with my 4G headlights.
Good luck if you decide to DIY. The above steps are really just a guideline since I have no experience with the 4G headlights.
TIA
TIA
Just follow the front bumper removal steps and the headlights come out fairly easily.
To clear the headlight you remove the amber lens. I would put some new projector lenses while your in there. TSX-R or another clear lens.
If you need more info let me know
i did it on mine.. very simple. i dont even need oven.
locals around our area.. jlclighting and member paperboy does it for around 125 or so.. way cheaper than what jnc is charging.
if your local, id do it for you for cheap.. it really only involves opening up and using autozone paint to black it out.. dont need to pay $300+ for a job like that..
You can do it at home but its a pain. I recently baked apart my headlights to fix my halos and you do it at 200C for 10-15 minutes. You can get some butyl sealant or reheat the factory sealant to reseal them. Remember to take out all the bulbs, I left my HID ballasts in though.
Where can you get Butyl sealant, Oreillys? Is that a better lens than the one that's currently in my 2012? Can I just order the TSX-R projector lens from the acura dealer?
http://www.theretrofitsource.com/pro...roducts_id=135
The only beef I have with the TSX-R lens is the fllicker is yellow/red ish making it not look too exotic, but they increase your output something like 20%.
I would try these if I had to do it again:
http://www.theretrofitsource.com/pro...ducts_id=25696
gibbyisgibby (11-09-2013)
2G TLX-S
Many members have been looking, but there is no DIY instructions for clearing 4G TL headlights.
Rather than screwing up an expensive headlight unit, let Jnc tackle the job.
Acutally everyone says the nissan butyl tape is the best stuff around, it like oem seal. Mine had so much sealant already because they had been previously opened that I just heated up what was already there, it was really messy lol. The "R" in TSX-R is for replica so its an aftermarket lens, its much better than whats in the TL currently. The place to get these things is the retrofit source.
I guess I will try to tackle this job myself soon.
Its hard to find, usually people get it off ebay, this is a similar product that should work as good:
http://www.theretrofitsource.com/pro...roducts_id=792
The following 2 users liked this post by gibbyisgibby:
KaleZ (11-09-2013),
ucf_bronco (11-10-2013)
Well, I've opened and blacked out both my 4th gen accord (glass) and my 03 Altima (plastic)...so, I'm not too hesitant to crack open the TL's lights (as soon as I have enough time/downtime to black them out too. Only key I would say is to not get the glue/sealant on the plastic when taking them apart or putting them back together. Oh, and make sure you use some high-temp sealant (dow-corning or some other weather durable silicone/sealant).
^^^ maybe I'll try it next time, but I NEVER have used OEM Nissan butyl sealant...I can't even remember the silicone I used for my Altima's lights...but here we are in 2013 and the lights have never had an issue with leaks nor condensation. I guess it also depends on your knowledge, skills and abilities to do things in the mechanical/engineering field...as a Heavy Mobile Mechanic for the DoD for the past 10 yrs...I know how to use my tools and materials and how to prep for the use of my sealants.
ijs
ijs
