Notices
Squealing noise from front of car
Old 04-05-2019, 10:48 PM
New Member
Hey guys,
Iím hoping someone has run into this problem and can help me. Iíve recently noticed a squealing/whistle sound coming from the front of my car. It only happens when Iím driving about 40 km/hr or higher then stops when I get below 40 km/hr. I thought it was a bearing issue but most mechanics are telling me itís not. I decided to replace the front passenger bearing and itís still making the same noise. Not sure if I should go and try and replace my driver side bearing... Thereís still a lot of brake pads left just to rule that out as well.
I drive a 2009 Acura TL SHAWD and it has about 170k km on it.
Thanks all!
Richard Chang is offline
Old 04-05-2019, 10:57 PM
New Member
Forgot to add this
Sorry forgot to mention I also just changed the accessory belt and have tried revving the engine in idle but no sounds. Kinda sounds like metal brushing on metal causing the squeal.
Old 04-06-2019, 12:41 PM
Registered Member
Reorge's Avatar
- Most likely source of noise is the pulley on tension arm. I change mine every time I change the belt.
- Could be alternator. Mine made a squealing noise when it failed.
- Reverify that the belt is installed correctly.
- Turn AC off and if the squeal is still there that eliminates the AC compressor as the culprit.
Reorge is online now
Old 04-06-2019, 01:28 PM
New Member
Would it make noise in idle for the alternator? Cause mine doesn’t. It only makes a noise when driving.
Old 04-06-2019, 01:40 PM
New Member
Apparently my mechanic is now saying it’s the drive shaft. I do hear some noise coming from there when we spin the wheels... I hope it’s not the problem since those are apparently quite pricey.
Old 04-06-2019, 10:20 PM
Registered Member
I have a 2012 TL Elite and had the exact same whining noise.
It was the propeller shaft.
AKSAKS is offline
Old 04-06-2019, 10:34 PM
New Member
Thanks for the response! Iíve read on some other posts on this but want to be certain since itís gonna cost me $1500 for the propeller shaft. Did it sound like itís coming from the front of the car when windows are up? Is the propeller shaft is in the middle of the car? My mechanic said he heard it from the drive shaft front passenger side... is that the same thing?
fliplyricist1
First Generation CL Discussion (1997-1999)
35
06-28-2008 08:24 PM
willz822
Third Generation TL (2004-2008)
21
08-30-2004 10:42 AM
mitchapalooza
01-07-2004 11:26 PM
anothercls
Second Generation CL Discussion (2000-2003)
12-30-2003 07:21 PM
CL_Racer
03-04-2003 07:35 PM
Quick Reply: Squealing noise from front of car
