RonJon 4th Gen Acura TL Body Kit Thread! **pg. 16 updated pics*
Old 05-03-2011, 09:17 PM
  #281
FallenTSX's Avatar
i will take pictures once its on and see what we can do to show it, but its up to Ron how he wants to do it
-DeL
Old 05-04-2011, 02:11 AM
  #282
Former Sponsor
rondog's Avatar
this is just preliminary testing of the first articles, the mounting points and hardware will be worked into thiese baseline parts or shells with no attachments points. THese do not represent the fitment, they are just shots of the process. surfaces and edges all have to be worked on a bit more, so these parts are about 80% done.
Old 05-04-2011, 04:21 AM
  #283
SSGHutch's Avatar
Looking great, any idea on when to expect the final product? I think this kit has turned out well
Old 05-04-2011, 05:23 AM
  #284
types1fan's Avatar
Looking good so far. Can't wait till the day it's on my car.
Old 05-04-2011, 07:25 AM
  #285
Former Sponsor
rondog's Avatar
taking forever, and we still have to make that splitter piece in the middle of the front lip to fill in the notched area. Soon though, this is the final stretch before the finish line.
Old 05-04-2011, 09:02 AM
  #286
SSGHutch's Avatar
I am content with waiting longer so long as it's because of quality control and fit and finish
Old 05-04-2011, 02:36 PM
  #287
neal5653's Avatar
Ron the kit looks good. Can you take some pics from further back so we can see the overall stance of the car with the kit
Old 05-05-2011, 11:48 PM
  #288
COTM Coordinator
MurkyRiversTL's Avatar
This kit has gone from decently aggressive to completely toned down. The sides dont even look the same as to what they were in the concept and the first test fit. I have to admit that I am a little disappointed with it and can only hope that the final product will bring the kit back to life.
Old 05-06-2011, 07:01 AM
  #289
Former Sponsor
rondog's Avatar
Easy Easy, the kit is not even shot properly, or painted. Wait until the final product is fitted, painted and shot professionally. Also, the front is going to have an optional splitter installed in the middle to add a little more aggressiveness. The kit has all the same exact features with dimensions to suite daily driving. 1.5" lower than the factory sides, front and rear, any lower would be a problem. I've seen this 100 times, the prototype looks too subdued, but in the end, it will be amazing, nothing really has changed if you compare it to Ryan's grigio TL with test fitted the mock up on...
95% the same kit:
Old 05-06-2011, 08:24 AM
  #290
COTM Coordinator
The cuts and angles are more defined on Ryan's test fit, mainly for the sideskirts. I know about the splitter and the fron looks great as well as the rear. Its the sides that I am concerned with. If you look at the forward most part of the sides on Ryan's compared to Del's you can see where that lower flare is removed and gives the sides a plain look.
If the final product looks more like the test fit on Ryan's car it will be perfect.
Old 05-06-2011, 08:28 AM
  #291
Stew4HD's Avatar
Received 1,092 Likes on 714 Posts
They look the same to me but hard to see with the sanded version. I could swear that I see the same angles and bevels on the side piece in both cases
Old 05-06-2011, 08:51 AM
  #292
Former Sponsor
rondog's Avatar
It's the lighting and texture of the parts, here are the parts in more dramatic lighting without dust all over the parts:
Old 05-06-2011, 10:08 AM
  #293
COTM Coordinator
The aft bevel is there. The forward bevel is not. The part that brings the line of the front lip into the sides. Give me a few and I will circle the part in the pics I am talking about. They do look much better after theyre cleaned up.
Old 05-06-2011, 10:21 AM
  #294
COTM Coordinator
You can see the difference in the circled areas.
Old 05-06-2011, 10:28 AM
  #295
Stew4HD's Avatar
Don't you think the new location looks better? The bevel seems to line up with the line coming down from the front of the door edge. IMO, they improved it.
Old 05-06-2011, 10:39 AM
  #296
COTM Coordinator
I completely agree that the top of the skirt looks better since it lines up and makes sense with the door line, but its the bottom part directly underneath that is missing the drop from the test fit on Ryan's car.
Surely I cant be the only one seeing this. Do I need to make my circles smaller???
Old 05-06-2011, 10:41 AM
  #297
Stew4HD's Avatar
Ah, yes, sorry, I see the missing "flare" on the front! I agree, that should still be there.
Old 05-06-2011, 11:14 AM
  #298
potmilkz's Avatar
Received 1,020 Likes on 792 Posts
i think that OEM looks much better.. due to that it wraps the inner side of the exhaust as well.
will the rear lip stick out from the bumper as it does not wrap around the licnese plate area?
how will the inner sides of the rear lip hold on to bumper? double sided tape? inner clips? it look like you can easily bump into something and it can come snap off. i can only say that the strongest mounting point you can have are near the inner fender area.
now if you incorporate the inner exhaust piece to your design, it would be fantastic
this is not to bash, just an opinion.
Old 05-06-2011, 12:28 PM
  #299
Stew4HD's Avatar
I wish I could say that about the OEM rear for the '12
Old 05-06-2011, 04:36 PM
  #300
-Brian
Nexson's Avatar
Well, you hit the front lip out of the water.
Old 05-06-2011, 05:00 PM
  #301
potmilkz's Avatar
is it me or do i not see a center line for that front lip...
Old 05-06-2011, 05:23 PM
  #302
-Brian
Nexson's Avatar
there doesn't need to be a center line. IMO I hate that center line crease.
Old 05-06-2011, 07:41 PM
  #303
COTM Coordinator
I think it should have the centerline so it flows with the bumper centerline. Its not a deal breaker but its not exactly matching the concept in design. I just hope there arent corners being cut to expedite the production. I promise if its built right and takes a bit longer it will be a huge hit. If corners are cut and it looks too plain it wont be as big of a success.
Old 05-07-2011, 01:30 AM
  #304
potmilkz's Avatar
without that centerline and all the details it just looks like an ebay lip to me..
Old 05-07-2011, 02:30 PM
  #305
Former Sponsor
rondog's Avatar
The fin on the sideskirt toward the front was taken out because it didn't flow into anything on the front lip, I tried to incorporate it into the front and it looked too forced in there. So we flowed the sides into the front and the entire flow of the kit from front to back seems alot more thought out and classy, not like it belongs on a civic, but rather a luxury sport sedan.
The front centerline was turned into an optional piece made from ABS that can be installed separately or left out all together to the owners' discretion. No lose situation.\
Cutting corners and RonJon Name brand do NOT belong in the same sentence. if we do something, it's because we tried it many different ways and the end result was the best way to us as a whole. We can't consult with all the board members on every little characteristic decision we make, we would never get it down with the different tastes everybody shares.
Old 05-07-2011, 06:40 PM
  #306
-Brian
Nexson's Avatar
Originally Posted by rondog
The fin on the sideskirt toward the front was taken out because it didn't flow into anything on the front lip, I tried to incorporate it into the front and it looked too forced in there. So we flowed the sides into the front and the entire flow of the kit from front to back seems alot more thought out and classy, not like it belongs on a civic, but rather a luxury sport sedan. The front centerline was turned into an optional piece made from ABS that can be installed separately or left out all together to the owners' discretion. No lose situation.\
plan and simple, the kit fits the car, not exotic, just subtle.
You can't make everyone happy.
Old 05-08-2011, 08:01 AM
  #307
Grandpa
George Knighton's Avatar
Received 2,609 Likes on 1,475 Posts
It looks good!
You've picked a design that is reasonably conservative but still makes the car stand out from the others. The kit hints at the sporty nature of the car without making an overt statement or appearing tacky.
Old 05-08-2011, 11:00 AM
  #308
Former Sponsor
rondog's Avatar
To do something like the OEM with the rear exhaust would require cutting of the bumper and drilling holes, we went with the next best thing which allows you to keep your OEM bumper unscathed, we also matched the cut on the OEM bumper right before the plate area. It will be held on with some 3M tape but the suggested option of silicone will be best, would seal the seam, keep the kit secure, and would be removable later if needed. A few "C" clips will be used as well in the exhaust openings and bottom side of the bumper.
Old 05-08-2011, 07:03 PM
  #309
neal5653's Avatar
it would be
fan
[QUOTE=potmilkz;12926807]i think that OEM looks much better.. due to that it wraps the inner side of the exhaust as well.
I disagree I think the Ronjon kit looks much better than the OEM rear. The Ronjon kit blends better with the lines on the car where the OEM version seems like an after thought. I see what you are saying about the RonJon kit not wrapping around the exsaust but I think once the kit is painted it will look
much better.I think when installed correctly you will not have to worry much about it popping off, adhesive technology has come a long
Old 05-11-2011, 08:41 PM
  #310
CapoTL's Avatar
the final model of this is gonna look killer!!
Old 05-20-2011, 10:30 AM
  #311
Former Sponsor
rondog's Avatar
Been a while, but Ryan's car is coming in on Monday with the shoot happening that same day. The kit is painted and ready to install, the splitter that goes in the front bottom is not finished, but we are crunching to complete that in time for the shoot, even if it's a prototype. Here are some pics of the kit painted before installation:
Old 05-20-2011, 10:42 AM
  #312
COTM Coordinator
Looks beautiful now. Cant wait for install pics. Im thinking that the side skirts may actually look better this way after seeing it painted.
Good job Rondy.
Old 05-20-2011, 11:31 AM
  #313
types1fan's Avatar
Looking good Ron,Cant wait.
Old 05-20-2011, 01:38 PM
  #314
Full of water...
blkaspec's Avatar
nice progress
Old 05-23-2011, 07:41 AM
  #315
2010_TL's Avatar
Can't wait to see this!!
Old 05-23-2011, 08:07 AM
  #316
VQPower37's Avatar
in for install pics
Old 05-23-2011, 08:23 AM
  #317
Pete2010's Avatar
Well, I was all fine with my car finally being "complete". I even spent like 6 hours washing/clay bar/sealant/waxing it this weekend. I pulled into an downhill parking spot and put a healthy gouge in my front lip. Look like I may be replacing that with this piece...
Old 05-23-2011, 02:53 PM
  #318
SSGHutch's Avatar
Someone Keyed my car! Well, at least I get a new paint job to go with the lip kit.... :/
Old 05-23-2011, 10:30 PM
  #319
Former Sponsor
rondog's Avatar
Couple of teasers, I had to edit the splitter because it's not done yet. Otherwise the pics are untouched. Tomorrow the pro shoot is scheduled and we will have hi res pics of everything. Behold!
Old 05-23-2011, 10:35 PM
  #320
CapoTL's Avatar
6SpdTerror (06-09-2011)
Quick Reply: RonJon 4th Gen Acura TL Body Kit Thread! **pg. 16 updated pics*
