Sponsored by: DashLynx
Resurface rotors or not?
Old 06-16-2016, 11:03 AM
disability space parker
mike in bmore's Avatar
I just had my 12 TL SH AWD serviced and was advised that my rear brakes were at 3mm. They suggested new pads and having a rotors resurfaced. My question for you is, is this necessary or the dealer feeding me a line of bs? Thanks in advance for advice.
Old 06-16-2016, 11:08 AM
Received 8,582 Likes on 6,629 Posts
Yes if replacing pads and you don't want to replace rotors hen you need to resurface them
mike in bmore (06-16-2016)
Old 06-16-2016, 11:48 AM
hadokenuh's Avatar
If you plan to drive the car for more than 10K miles, then replace the rotors.
If you plan to trade it soon, just resurface them.
The following 2 users liked this post by hadokenuh:
mike in bmore (06-16-2016), Mr Marco (06-19-2016)
Old 06-16-2016, 11:57 AM
KarKraze's Avatar
Check the price difference between new rotors and cost of resurface. Resurfacing rotors today is hardly worth it if you are keeping the car for a while because you will have to replace it soon enough and it is another labor charge.
Old 06-16-2016, 12:24 PM
CTNYC's Avatar
I second KarKraze's post... I'd take it a step further and say to get some good quality aftermarket brake pads and rotors and just go to the dealership or a local indy shop for the labor.
Old 06-16-2016, 12:33 PM
ReyesMX's Avatar
I would second CTNYC on the aftermarket pads and rotors. Just make sure they are better than what you have already and have some good history of reviews. Most of the time you can come out with a better price on aftermarket than OEM, especially from a dealer.
Old 06-16-2016, 09:13 PM
dzionny_dzionassi's Avatar
Question it is why you need to resurface? IS you braking shimmy, or there is rust on braking surface? If not, don't touch your rotors.....
Old 06-18-2016, 07:01 AM
acupower's Avatar
Sometimes if you have a slightly off-balance hub the only way to get rid of vibrations is to resurface. The resurfacing gets your rotor perfectly balanced to your hub.
Having said that, I would always go with resurfacing if it is not overly expensive and if the rotor has sufficient thickness. Problem is that resurfacing often costs more than an aftermarket rotor.
Old 06-18-2016, 11:15 AM
WheelMcCoy's Avatar
Resurfacing rotors is the proper and complete thing to. It cleans any rust, brake dust, and any film, and deposits left from the old brake pads. This ensures a good surface for the new brake pads to work on. High performance brakes need a "bed-in" process, and mechanics simplify that advice for regular drivers by saying be easy on the brakes for the first 500 miles.
DIY guys typically don't have the equipment to turn the rotors, and for the most part, wiping down the rotors with brake cleaner and changing the pads work, but that isn't ideal. But DIY guys do it for fun and to save money. I see the OP is in Baltimore. I'm in NY. With winter snow and salt, I'd go for the resurfacing.
Old 06-18-2016, 07:47 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
for most drivers it is not needed on the first brake pad change unless you get a vibration while braking. If the rotors are nearing the thickness limit, you can buy blank rotors online for 1/2 the price of getting the old ones resurfaced.
Old 06-19-2016, 09:53 AM
Mr Marco's Avatar
+1
Aside from the cost issues, these Honda rotors are prone to warpage. Cutting them down even thinner makes sets you up for a pulsing in your pedal.
Old 06-20-2016, 10:11 AM
CTNYC's Avatar
Originally Posted by Mr Marco
+1
Yup - All 4 rotors on my TL that I bought used were resurfaced ~60k miles according to service records... It was fine until around 110k, but now at 115k, I'm definitely getting more pulsating... I figure that I'll need a brake job soon - Will probably just replace both rotors and pads on a day off...
Old 06-21-2016, 09:21 AM
firebretha's Avatar
another vote to just replacing them. Now the cost of labor has increased and the product manufacturing cost decreased. So of course its easier to replace than just service.
Old 06-23-2016, 10:09 PM
WNY PAT's Avatar
If you're keeping the car a long time, get a high end set of rotors and pads all the way around. The stock rotors are ok but IMO, they're not worth resurfacing.
z643167z
04-24-2016 11:23 AM
kostantinos
2G TSX Problems & Fixes
116
03-30-2016 10:18 AM
Puppetmaster
03-25-2016 06:40 PM
Mjakaz09TL
02-06-2016 04:31 PM
Quick Reply: Resurface rotors or not?
