Replacing Key Fob Slot Holder
Old 01-16-2018, 08:28 PM
Kinuto's Avatar
Hello everyone I just ordered my replacement key slot holder for my 2013 Acura TL with Tech Package and I知 wondering if I should replace it myself or have a dealer do the job. Is there any special key programming needed or is it just plug and play?
Old 01-16-2018, 08:29 PM
Kinuto's Avatar
This is a pic of the part I知 talking about. Part number 36990-TK4-A01
Old 01-16-2018, 08:46 PM
Forum Contributor
EE4Life's Avatar
Received 1,391 Likes on 643 Posts
2013 TL - Keyless Access Remote Slot Test/Replacement
https://techinfo.honda.com/rjanisis/...untry=1&lang=0
The following 2 users liked this post by EE4Life:
Kinuto (01-16-2018), yerbation (07-20-2019)
Old 01-16-2018, 09:15 PM
Kinuto's Avatar
Thanks that should help with the tear down of everything.
Old 01-17-2018, 08:23 AM
Kinuto's Avatar
Should the battery be disconnected while performing this swap of the key slot?
Old 01-18-2018, 08:33 AM
losiglow's Avatar
Probably a good idea. What happened to the slot? Seems like a part that wouldn't really go bad.
Old 01-18-2018, 08:51 AM
Kinuto's Avatar
Dealer who sold me the car in attempt to repair it shoved pliers in it and ripped off the teeth that hold the key in the slot. I just discovered this nearly a year later.
Attached Thumbnails Replacing Key Fob Slot Holder-9af36f8b-598a-4a49-8a15-735e2cb6d89c.jpeg
Old 01-18-2018, 11:11 AM
Received 8,575 Likes on 6,626 Posts
have them fix it?
Old 01-18-2018, 11:17 AM
Kinuto's Avatar
have them fix it?
Car is out of warranty. Acura Dealer wants $200 just to pull a penal off and unscrew the key slot.
Old 01-19-2018, 09:18 AM
losiglow's Avatar
It's been months since I put my FOB in the slot. I just keep it in my pocket. The only reason I put it in the slot a few months back was because the battery was dying and the HID was prompting me to put it in the slot due to the battery. Replaced the battery - haven't put it in since
Old 01-19-2018, 09:36 AM
Kinuto's Avatar
Yeah that痴 pretty much what it is for. A back up in case your key fob battery dies. Tomorrow I値l be pulling out the panel and posting pics of the process. I feel like this is important cause eventually someone else will experience a broken slot and they can always look back at this for help.
mountain40 (03-02-2024)
Old 01-19-2018, 09:49 AM
losiglow's Avatar
^ I'm sure someone will appreciate it down the road
Old 01-19-2018, 11:52 PM
Kinuto's Avatar
Got everything out except this screw which is stripped. Any suggestions on how to get it out?
This is second screw came out with force.
Old 01-20-2018, 08:48 AM
Kinuto's Avatar
First off a good set of auto trim pry tools should be a good help for removing the trim. It can be stiff at times but remembe to pull up and it値l snap off.
Start at the edges from bottom to the upper console.
Soon you値l be good to go! Now to remove the key slot.
Notice all my clips underneath the panel.
The key slot exposed.
You can pull off the push start button from the connector nothing bad will happen. Everything in the car will function normally.
There痴 two self tapping screws with a lock tight washer in the back be careful or you値l end up like I did having the pry the screws out. Make sure you have the proper screw driver so you don稚 strip screw heads.
Now put everything back to together. I started from the top to the bottom. Sadly I lost a screw in the upper corner due to the thread being stripped badly so I had to use only one screw which survived. Everything is pretty tight now that the panel rest on the slot. Eventually I値l replace the missing screw.
The following 3 users liked this post by Kinuto:
echodigital (01-22-2018), fryrice (01-29-2018), hadokenuh (01-14-2020)
Old 01-20-2018, 08:50 AM
Kinuto's Avatar
The screw and washer that gave me hell. Hopefully you guys can help me figure out this part regarding the screws washer at the end.
Old 01-27-2018, 12:52 PM
Kinuto's Avatar
I took everything apart again and managed to put the clip like washer back in place. I even replaced the screw since it was stripped.
echodigital (09-01-2021), fryrice (01-29-2018), itsfr (07-12-2018)
Old 07-20-2019, 09:08 PM
yerbation's Avatar
Same Problem
I have a 2009 Tl w.Tech Pkg and it has the same problem, doing it yourself did it work ?
Old 07-21-2019, 05:42 AM
Kinuto's Avatar
Yes it痴 an easy job and quick fix. Just take your time and look at the steps I posted on this thread. I haven稚 had an issue with my key fob slot holder since replacing it with a new unit.
Old 01-08-2020, 08:25 PM
jorge vargaz's Avatar
Replace key fon slot Holder acura tl 10
ne how
Old 08-31-2021, 04:11 PM
mrphilipanderson's Avatar
Originally Posted by jorge vargaz
ne how
did the key need to be reprogrammed after replacement?
Old 08-31-2021, 04:47 PM
Kinuto's Avatar
No programming necessary. It's a direct swap.
Old 08-31-2021, 05:01 PM
I have to replace mine soon. It got stuck today. and used pliers. But I knwo eventually im gonna have to fix it. So I can just pull the part ot after remove the two front facing screws? The pictures with all the ads make it all so confusing. The ads they site placed over and between your pics you posted of your swap...
Old 08-31-2021, 06:55 PM
how do I access the link? It doesnt work for me ?
Old 08-31-2021, 08:28 PM
Kinuto's Avatar
SMH that's annoying that they put ads on them. Get yourself some trim removal tools so you can pry the center console areas that have the keyfob slot alongside it. Be very gentle when removing the trim and make sure you push the retainer clip on the push start button so it releases from the trim. The 2 front facing screws should come off easy and it's plug and play from there.
Old 09-01-2021, 11:30 AM
Youre an awesome human being!
Old 09-01-2021, 04:10 PM
Kinuto's Avatar
Thank you Phil! Not sure if you knew but I moved on from the 4G TL. This generation will always have a place in my heart.
My 2021 Acura TLX A-Spec Package with SH-AWD in Performance Pearl Red.
Old 09-01-2021, 04:48 PM
Awww now I really wanna get a different car I think I may get a tesla.
Old 09-01-2021, 05:05 PM
Kinuto's Avatar
That would be a good idea as well since most cars are going electric in the future.
Old 09-03-2021, 10:15 PM
Joblack's Avatar
My folks got a Tesla Model Y recently. It is very nice to drive. The Tl’s have higher quality interiors. Tesla’s are faster. I will keep a car with a clutch pedal until the day that my car drives me to work while I am sleeping 😴 💤
Old 10-23-2022, 01:40 AM
jmendoza17's Avatar
Any chance you can repost that link. I am having same problem as Kinuto. Thank you if you can
Old 10-23-2022, 01:43 PM
altair47's Avatar
Have you tried to simply stop using key slot holder?
Old 10-23-2022, 01:46 PM
jmendoza17's Avatar
LOL. I have. Seems easy enough but habits are hard to break so a plug may do it. My family drives it occasionally and also does not remember.
Old 10-23-2022, 01:50 PM
altair47's Avatar
I understood you. I immediately stopped using it after I found out what it could break, a bunch of keys makes less sound if they are in the cup holder.
Old 02-05-2024, 03:35 PM
BlackAc'TL*2010's Avatar
Key fob receptacle replacement
Hey man just wondering where did you order this part? Having major troubles locating this part for purchase, it has been discontinued in the factory, so i likely will need to get a salvaged one from a wrecker. Just wondering if theres anywhere that would have it still in stock??
Im in the same boat, key fob insert fkd up and held key first time ever, upon jimmying it out with some force busted a plastic piece inside and now the car thinks theres always a fob in it, therefore will not operate any of the keyless entry features nor can i lock/unlock my doors without the manual key.
Super thankful you posted about this issue , it doesnt seem to be super common. Any other help would be useful and greatly appreciated, thanks!
Old 02-05-2024, 03:42 PM
https://www.oemacuraparts.com/oem-pa...ob-36990tk4a01
looks available here
wasabe918
12-28-2011 11:09 PM
cbrose
04-08-2010 09:39 AM
carrollb
01-07-2010 11:01 PM
GsrRussell
08-07-2007 12:38 PM
msingh
03-30-2006 03:11 PM
Quick Reply: Replacing Key Fob Slot Holder
