Replacing Fender Liner - How many clips?
The fender lining has ~4 different sets of screws/clips associated with it. I know all the part numbers but was hoping someone might know the exact number of each required. Also, as much as everyone loves AcuraOEMParts, they have absolutely 0 mention of the number of an item required - I'll stick to Bernardi that at least tells me how many a diagram section needs.
Genuine Acura OEM Automotive Parts Catalog - Bernardi Parts
Body/Air Conditioning - Front Fenders
Part #19 in the diagram 91512-SX0-003 has a required quantity of 8. I don't see it anywhere else in the diagram so I assume 4 per side.
Part #17 though is where I'd like clarification, 91505-S9A-003 has a required quantity of 18. It's also referenced along the front undertray (~4 used here?) which leaves 14 - I assume 7 per fender lining then?
Has anyone gone through the process? They're not terribly expensive but at the same time I don't want to spend $2/clip on ones I'm not going to use.
The following 2 users liked this post by omgitsspooky:
EvilVirus (10-25-2016),
TheMuffinMan (09-28-2016)
-greg
You are correct in your assumptions in regards to the quantities needed. It's a total of four(4) on part number 91512-SX0-003 and a total of seven(7) for part number 91505-S9A-003. I've gone through the process numerous times over the years selling OEM Honda and Acura parts. Any questions, let me know!
-greg
-greg
Without crawling up under the car (it's drizzly today!) I figured this would be the second best place to check. I stopped by the dealer and made the order.
So as an update (finally go around to having my car fixed)
Required quantities are actually incorrect!
For a full fender lining replacement you need:
4 x 91512-SX0-003 (which has been replaced by 91501-S04-003)
- These are the main clips (aside from the 4 screws) that go along the top of the fender lining
3 x 91505-S9A-003
- Two go from the fender lining into the front bumper, one goes at the bottom/rear by the fender. *Might* be 4 of them,
1 x 91506-S9A-003
- This holds the underbody splash shield up to the vehicle on either end.
Hopefully this helps others. The large number required for 91505-S9A-003 is for the underbody splash shield which takes a million of them. I ended up replacing this part as well so I used the clips I purchased otherwise they would not have been required.
3 x 91505-S9A-003
1 x 91506-S9A-003
For clips I just buy OEM, it costs a boat load (most recent trip was ~$40 in clips alone) but I'm guaranteed they fit.
*edit* Agree with csmeance, those are the ones for the plastic covers in the engine bay.
Which ones? csmeance might have gotten them, I'd need to check though.
yea those were the ones i was looking for.. stupid acura lost a few of them when they were done with my car..
3 x 91505-S9A-003
1 x 91506-S9A-003
3 x 91505-S9A-003
1 x 91506-S9A-003
