Repair Droopy Sun Visor?
Old 05-10-2018, 06:26 PM
Papa Roe's Avatar
The sun visor on the drivers side has been loose for quite a while. I cannot figure out how to remove the plastic cover to see if the screws are loose, or that the entire thing needs to be replace. Has anyone out there popped of that little cover, and if so how?
Old 05-13-2018, 08:33 PM
Anicra's Avatar
Bottom of Page 1792 and 1793 of the Acura Repair Manual
see thread https://acurazine.com/forums/fourth-...manual-956811/
for the manual
1. Insert a flat-tip screwdriver through the hole in the front side of the bracket cover (A), and push the hook
(B). Make sure the hook is unlocked.
2. While pushing in the hook (A) with a flat-tip screwdriver, release the sunvisor (B) from the holder (C),
and rotate the sunvisor backward about 45°. Make sure the hook slides into the bracket cover as you
3. Pull down the sunvisor (A) to release the pin (B) and the bracket (C) from the holes in the body. Then
pull out the vanity mirror light connector (D), and disconnect it.
Manual had pictures that better describe it.
The following 2 users liked this post by Anicra:
echodigital (05-15-2018), Papa Roe (05-18-2018)
paperboy42190
05-21-2013 08:29 PM
xedap1998
07-19-2005 10:54 AM
euroStyle
Wash & Wax
06-28-2005 09:46 PM
us000011
01-03-2005 07:17 AM
SidVicious
04-18-2001 01:39 PM
Quick Reply: Repair Droopy Sun Visor?
