Rear Cam moved while doing timing belt?
I'm in the process of reinstalling my timing belt. My crankshaft is TDC, so it my front cam - at 1. However my rear cam seems to have rotated counter clockwise a number of teeth and now its off. How to I readjust this to TDC on the mark without breaking anything? Thank you for any help.
Take a 17mm wrench and turn the rear cam back towards you. Make sure both cames are back at tdc and reinstall the tbelt. Apply tension to the belt then recheck tdc. Spin The crank clockwise a few cycles then recheck tdc to confirm its fixed. If spinning the crank by hand a few cycles, make sure if it gets real tight, timing is probably off
teh CL (10-29-2017)
Question on coolant. Do I just refill the rad full, then the overflow tank to max and let the engine run for a bit on full hot with the tank overflow cap off to burp system?
I just wasn't sure which way to turn the cam pully, some refrences say only CCW, other doesn't matter. In any case I put the rear cam back to TDC and installed the belt. Couple revolutions and everything is TDC.
I would prefer using a coolant fill funnel that comes with universal radiator fill caps. FULLY burps the system. Only $20-25 and universal. Brand i have is Lisle i believe.
All you have to do it watch the coolant in the funnel and wait until the fluid stops bubbling and voila you done diddly.
teh CL (10-29-2017)
Big no no! You will just overheat. You have the car on heat on hot part right. Can also hold rev around 2k if you want to speed up the process. Let fan kick on 2 times.
