Sponsored by: DashLynx
Preferred fluid change method
Old 04-23-2018, 11:35 PM
Rancher2005's Avatar
For replacing fluids that have a check bolt to confirm they are full (front differential / manual transmission), do most of you raise the vehicle up at all four corners onto jack stands, use ramps at only one end, or some other method?
I'll be doing the fluid changes above but understand the vehicle should be level and filled to the point of slight overflow from the check bolts. What do you recommend without a lift or a pit?
Old 04-24-2018, 08:41 AM
Received 16,260 Likes on 11,971 Posts
as YOU stated...the car has to be LEVEL.
DO whatever you need to do to get the car LEVEL.
so, if that means bringing it to a pit...
or if that means driving it up on ramps, then lifting the rear to match...
you get the picture. DO WHATEVER YOU NEED TO DO to get the car level.
because if it's not level, you wont get the correct amount of fluid in there.
Old 04-24-2018, 08:44 AM
I, personally, have 4 jackstands. SUPER easy to lift the car and put it on 4 jack stands
The following 2 users liked this post by justnspace:
Anicra (04-24-2018), Rancher2005 (04-25-2018)
Old 04-24-2018, 10:19 AM
Anicra's Avatar
I use the 4 jackstands + usually a jack on the hook on the back (pressed up against the car however not taking any weight, ready to take weight in case of massive craton earthquake). Basically 4 stands, mostly what the porn crab-man said.
The following 2 users liked this post by Anicra:
justnspace (04-24-2018), Rancher2005 (04-25-2018)
Old 04-24-2018, 10:36 AM
the good news is; you're not buying floor jacks and jack stands every month, or even every year.
they are good tools to have.
I have a Harbor freight aluminium floor jack....which on road trips I take along with me. It's light enough and breaks down small enough to fit in my trunk.
Old 04-24-2018, 11:26 AM
VanyDotK's Avatar
I just did my transmission fluid and transfer case fluid last month, I used four jacks and a level (overkill, I know).
Received 8,582 Likes on 6,629 Posts
I have my four friends (all named Jack) stand at each corner of the car and deadlift it.
Old 04-24-2018, 12:01 PM
I think my jack stands are different brands...same general height...just off by a little.
if I dont pair the same brands together, the car sits at a slant. lol
Old 04-24-2018, 05:17 PM
Thanks for the responses. I guess I wasn't sure how many of you would be comfortable simply draining and filling to the specified capacity. I think that is what I did for SH-AWD sauce in the rear diff. When I had my type s I did the 3x3 in the garage on borrowed stands intended for a truck/ suv. The minimum height made it a challenge to jack high enough. I will just try to get smaller matching pairs of stands.
Old 04-24-2018, 07:11 PM
VanyDotK's Avatar
My jack stands are the same brand, but my garage isn't level, so when I was filling the fluid I had to slightly lift the front end of my car higher to get it level, again, overkill I know. On the upside, my shifts are so much smoother now, I wish I changed the fluid earlier.
Old 04-27-2018, 03:04 PM
Reorge's Avatar
I can change the dif fluid without raising the car. I'm 5'11 and 230 lbs
tekeTL
07-06-2012 03:34 PM
friesm2000
10-06-2009 11:04 AM
Josh99CL
04-03-2009 02:34 PM
Stoodo
1G RDX (2007-2012)
05-22-2007 07:07 PM
Quick Reply: Preferred fluid change method
