Go Back  AcuraZine - Acura Enthusiast Community > AcuraZine TL/TLX Community > Fourth Generation TL (2009-2014)
Reload this Page >
New owner, Just replaced clutch, car feels like stalling
Notices
Old 05-01-2019, 07:55 PM
New Member
Hey all,
Iím the new owner of a 2012 TL SH-AWD. Car had about 56k miles when I got it and I put about 1500 since then.
It is my first manual car and unfortunately I burned the clutch a bit while I was learning. I needed to replace the ball joints (dealer supplied) and figured I could save a little on labor costs by replacing the clutch at the same time. While the clutch didnít need to be replaced at that moment, the engagement point was very high and shifting into 2nd was becoming more and more difficult every day, I felt it was detrimental to learning how to drive stick.
Fast forward to today, I just picked up the car from the mechanic after a 2-day job on the clutch, and I feel the clutch has very little resistance compared to before. About the same resistance as pressing the gas pedal. Additionally, the clutch begins to bite after I lift off about an inch before, which is vastly different than what it was before when it was near the top of the pedal throw.
This wouldnít really pose a problem, except that it feels like the car is stalling as soon as the clutch begins to grab. Giving it gas when the clutch grabs doesnít help either, as it feels like the car is shaking itself to death until the clutch pedal is near the top. Shifting into gears is okay, but trying to move around in 1st and reverse feels like Iím making a lot of wear on the brand new clutch.
Has this been typical of anyone else who has replaced their clutch? Before, I was able to get the car moving from a stop with just the clutch (but I know that lugs the engine so I donít do that anymore), but now the car does not move at all at the biting point and instead it will shake and feel like it will stall.
4gBWP is offline
Old 05-02-2019, 09:42 AM
Registered Member
TheMuffinMan's Avatar
Maybe have someone that hasn't destroyed a clutch in 1500 miles drive the car and see what they think?
You can adjust the clutch engagement point for the pedal.
TheMuffinMan is offline
Old 05-02-2019, 10:14 AM
New Member
The clutch was on its way out but I wouldn't say I "destroyed" it. The first two weeks was a learning experience before I fully got the hang of it. Its not like the car could not be driven. There was no slippage throughout the rpm range before the replacement. I only replaced the clutch as it often felt like I was locked out of 2nd gear, requiring more force than expected to get the shifter in there.
I've seen the thread about adjusting the engagement point, but is it possible to adjust the engagement point to where it either doesnt fully disengage or engage?
I've also seen other threads elsewhere that indicate that new clutches shudder/shake for the first few hundred miles. Even so, the spongy pedal feeling with little resistance makes me feel uneasy, especially when everyone on here states that their clutch engages high up.
4gBWP is offline
Old 05-02-2019, 10:25 AM
Received 13,979 Likes on 10,384 Posts
no way should a new clutch shudder and shake for the first few hundred miles.
justnspace is offline
Old 05-02-2019, 10:26 AM
with that being said; it sounds like the pedal position is at play here. see if an adjustment can be made at the pedal
Old 05-03-2019, 09:13 PM
Registered Member
Anicra's Avatar
Still cannot believe TheMuffinMan sold his TL. Ya have someone else drive who is fluent in clutch, see what they think. Or have a local trust-able shop drive it once.
Anicra is offline
Old 05-07-2019, 10:24 AM
Registered Member
If it makes you feel better I don't love the Golf R. Will probably swap it out for something else in a year or so. TL was a comfy cruiser.
piggydog
11-27-2009 08:57 PM
heyitsvu
Second Generation CL Discussion (2000-2003)
10-29-2009 02:12 AM
IvanAndreevich
First Generation CL Discussion (1997-1999)
06-22-2009 12:54 AM
JayT
01-29-2009 08:58 PM
Final
Third Generation TL (2004-2008)
11-04-2006 07:14 PM
Quick Reply: New owner, Just replaced clutch, car feels like stalling
