New to AZ and new owner of 2013 Acura TL SH-AWD needs help!
Hey ladies and gents!
I'm a new personnel on AZ, never owned an Acura before. Was always a honda fan. Decided to buy me an awsome 2013 Acura TL Sh-AWD. I gotta say I'm loving the damn vehicle a lot! I wanted to start out by saying I need help with headlights and fog lights, I've already got my tints on. I'm not very good with vehicle modding, and so that's the reason why I came to AZ to get some experience details from the acura community. 1) I just wanted to switch out the headlights for some better quality LED preferably 6k. I don't know where to buy. 2) same as above but for fog lights. 3) would it be ugly to put some halo lights on? And is it possible to put on lumen lights as well? And just using the OEM headlight assembly. Thanks guys!! And tips and help would be appreciated! Maybe this thread can help others out as well. Hope to hear from the Acura family! |
1) LED lights are going to give less output than your HID lights you have.
2) You can put LED bulbs in your foglights. Again, probably less output than your halogens but won't be dangerous. 3) Lumens are a measurement of light output...not sure exactly what you mean? I don't like halos myself in cars that didn't come with them, but some people have put them on and they look fine. |
For best light output get Osram CBI bulbs
Originally Posted by BSG1
(Post 15082264)
2) You can put LED bulbs in your foglights. Again, probably less output than your halogens but won't be dangerous. 3) Lumens are a measurement of light output...not sure exactly what you mean? I don't like halos myself in cars that didn't come with them, but some people have put them on and they look fine. Thanks |
Originally Posted by VanyDotK
(Post 15082304)
Oh by the way guys would I need ballast for both low beam and fog light as well?
Originally Posted by baowheezy
(Post 15082318)
So does that mean I should go with Aftermaket HIDs? For both low beam and fog lights? And what do you mean less dangerous for LED?
Thanks When I mention less dangerous, I mean putting LEDs in for headlights will give less light output onto the roads, making it more dangerous than just swapping in LEDs for the fogs, which would be primarily for looks, but they're not the main source of lighting. I'm assuming you may be going for looks on these lighting upgrades? |
(Post 15082086)
I'm a new personnel on AZ, never owned an Acura before. Was always a honda fan. Decided to buy me an awsome 2013 Acura TL Sh-AWD. I gotta say I'm loving the damn vehicle a lot! I wanted to start out by saying I need help with headlights and fog lights, I've already got my tints on. I'm not very good with vehicle modding, and so that's the reason why I came to AZ to get some experience details from the acura community. 1) I just wanted to switch out the headlights for some better quality LED preferably 6k. I don't know where to buy. 2) same as above but for fog lights. 3) would it be ugly to put some halo lights on? And is it possible to put on lumen lights as well? And just using the OEM headlight assembly. Thanks guys!! And tips and help would be appreciated! Maybe this thread can help others out as well. Hope to hear from the Acura family! https://acurazine.com/forums/4g-tl-photograph-gallery-296/just-finished-full-carbon-grill-909932/#post15076490 |
(Post 15082354)
What exactly are you trying to accomplish? If you want more light output, you may try the bulbs VanyDotK mentioned. Thought I'm not sure how much more lumens exactly they put out compared to OEM bulbs. Otherwise if you want more of a blue/purple color, you'll lose light output by increasing the kelvins and reducing lumens.
When I mention less dangerous, I mean putting LEDs in for headlights will give less light output onto the roads, making it more dangerous than just swapping in LEDs for the fogs, which would be primarily for looks, but they're not the main source of lighting. I'm assuming you may be going for looks on these lighting upgrades? http://www.hidextra.com/d2s-6000k-hid-kit/ |
Originally Posted by jterp7
(Post 15082407)
check this thread on angel eyes...not the easiest based on his experience though
https://acurazine.com/forums/showthread.php?p=15076490 |
(Post 15082512)
Hi sorry let me clarify. I just want to change the low beam lights to after markets HIDs. Would I buy these? Let's just scratch the halos and lumen lights.
(Post 15082604)
Just FYI the 4G TL uses bi-xenon projectors which means your low beams are also your high beams. Also, the 4G TL comes with HIDs, you do not need a kit. Your best bet is to change the bulbs that came with your car to Osram CBI D2S bulbs, they give you a bit more color with a bit more lumen as well. Google the bulbs to find more information, there are threads out there with comparison pictures.
(Post 15082604)
(Post 15082658)
Oh by the way vanydotk, what would be the best bulb to change too for the drl?
Anyway, when is the RV6 j-pipe going to cone back in stock?! |
(Post 15082604)
No bi-xenon on 4g. Our DRL and high beam are the same halogen bulb. Our low beams are factory HID. |
Originally Posted by LNJ
(Post 15082764)
(Post 15082604)
(Post 15082764)
Thanks |
9005 I believe is the hi-beam/drl bulb. I haven't changed mine yet but there are a few threads about what most owners have done.
Apparently even getting the whitest halogen doesn't help much during low voltage DRL mode cause it still doesn't show up as white as HID or LED. Even the blueish tinted ones have a slight yellow hue in DRL mode but not as bad as stock bulbs. |
(Post 15082856)
(Post 15082856)
Apparently even getting the whitest halogen doesn't help much during low voltage DRL mode cause it still doesn't show up as white as HID or LED. Even the blueish tinted ones have a slight yellow hue in DRL mode but not as bad as stock bulbs. http://www.ebay.com/itm/NEW-PAIR-2X-OSRAM-XENARC-D2S-66240CBI-COOL-BLUE-INTENSE-5500K-HID-XENON-BULBS-/221431577620?pt=Motors_Car_Truck_Parts_Accessories&hash=item338e59bc14&vxp=mtr |
(Post 15082604)
(Post 15083375)
Oh by the way LNJ, does this look legit? They're the Osram CBI d2s.
New Pair 2X OSRAM Xenarc D2S 66240CBI Cool Blue Intense 5500K HID Xenon Bulbs | eBay |
(Post 15083375)
New Pair 2X OSRAM Xenarc D2S 66240CBI Cool Blue Intense 5500K HID Xenon Bulbs | eBay http://www.theretrofitsource.com/com...cbi-49013.html |
Post a pic of your car.
