Notices
In-line Transmission Filter Help!
Old 05-07-2019, 07:14 PM
New Member
Does anyone know the exact part # for the inline transmission filter on the 2012 Acura TL?
I called my Acura Parts Store and they are charging $146.67! I don't think he is looking at the right parts. Also, if that is the price, Amazon said this one fits:
https://www.amazon.com/gp/product/B01J1LPYVI/ref=ox_sc_act_title_1?smid=A2F8QH83YSA2LG&psc=1 https://www.amazon.com/gp/product/B01J1LPYVI/ref=ox_sc_act_title_1?smid=A2F8QH83YSA2LG&psc=1
O'reilly's, ABC Auto, and Advance Auto parts don't carry any.
Thanks!
ZekeR7 is offline
Old 05-07-2019, 07:15 PM
Received 5,846 Likes on 4,687 Posts
www.oemacuraparts.com
Put in your car and go to Transmission and you can find the filter there.
thoiboi is offline
Old 05-07-2019, 07:28 PM
New Member
Thanks!
ZekeR7 is offline
Old 05-08-2019, 09:55 AM
Registered Member
Reorge's Avatar
Item 4:
https://www.acurapartsforless.com/v-...e-atf-pipe-6at
Or non-oem ATP brand (I've used these on my TL, son's Accord, and daughter's TSX)
So YES, the one you noted on Amazon.com will work
https://www.rockauto.com/en/moreinfo...501069&jsn=368
Reorge is offline
Old 05-08-2019, 10:09 AM
Registered Member
losiglow's Avatar
I've used the 3/8" Magnafine filter with good results. It filters out particles down to 3um and also has a built in magnet to further capture metallic (ferrous) material, regardless of size.
https://www.magnefinefilters.com/NEW...8M-3810000.htm
losiglow is offline
Old 05-08-2019, 01:04 PM
New Member
Did you have to modify the brackets?
ZekeR7 is offline
Old 05-08-2019, 03:35 PM
New Member
https://www.amazon.com/gp/product/B0...83YSA2LG&psc=1
Thanks!
I installed the Amazon part....worked fine on my 2012 TL advance. Helped to remove the battery case.
Lester.Dixon is offline
Old 05-09-2019, 10:07 AM
Slyonefoya
Sylvester Womack is offline
Old 05-09-2019, 11:00 AM
Registered Member
losiglow's Avatar
Nope. No modification needed. The only issue is that you have to make sure it's not connected backwards. IIRC, the fluid is pumped from the "bottom" of the transmission, which enters on the right side of the filter if looking down at it, and then out the left side, to the radiator, then to the fluid cooler, then back to the transmission. The stock filter (and most aftermarket filters that use the same type of housing to OEM), are built as such to largely avoid connecting the filter backwards since they only fit one way on the bracket. However, the Magnafine isn't built with the same housing as the OEM filter and thus, it's possible to connect it backwards. Connecting it backwards can impede flow which can damage the transmission.
But all you have to do is remember than the fluid flows from right to left, then connect the Magnafine filter so the fluid is flowing that way. The filter itself has arrows to show which way the fluid should flow.
losiglow is offline
Old 05-17-2019, 12:05 PM
dv-
Registered Member
How often do these filters need to be replaced? Every fluid change?
dv- is offline
Old 05-17-2019, 12:23 PM
Registered Member
Reorge's Avatar
I change mine every 30k miles
Reorge is offline
dv- (05-17-2019)
Old 05-20-2019, 10:24 AM
Registered Member
So I changed out my filter this past weekend. Once you remove the battery tray it is simple to change the filter (2 hose clamps and 1 retainer bolt holding the filter in place). However, whoever at Acura decided to add an additional bolt to the underside of the battery tray was not a nice person, nothing like leaning over the hood with both hands under the tray trying to find a hole you can't see
AnotherTL is offline
Old 05-20-2019, 10:52 AM
Registered Member
losiglow's Avatar
Yeah, the tray is all sorts of fun to remove.
Similar to Reorge, I change mine every other ATF change which is about 30K miles. I've cut two of them apart (OEM and the Magnafine) and remove the filter media. It was pretty clear that both had plenty of filtering capacity left. They could probably go longer but it's a cheap and relatively easy maintenance item to potentially extend the life of the transmission. It's about time that Acura figured out that an ATF cooler and serviceable filter help keep their transmissions from dying
losiglow is offline
Joberube
07-18-2013 10:32 PM
JayK
08-31-2011 07:06 PM
mmade22
12-27-2008 09:36 AM
demolition_x
Second Generation TL (1999-2003)
08-30-2004 05:08 PM
Quick Reply: In-line Transmission Filter Help!
