Notices
LED high beams upgrade
Old 05-09-2019, 11:50 PM
Registered Member
Unknownerror0010011's Avatar
I know there are threads about LED high beams but i thought i would give people another option besides the IJDMtoy ones. The Hikari LED's on Amazon are amazing and are functional 100 better than the halogens. I didnt buy the resistor and i have no codes or flickering i recommend them to anyone looking get good quality LED's that are an improvement not only aesthetically but also improve functionality.
DRL
DRL
Unknownerror0010011 is offline
Old 05-10-2019, 07:50 AM
Subsonic
Teddybear's Avatar
nice! i've been looking at switching my drl/hi beam to LEDs, but weren't sure which ones would take the lower drl voltages without flickering
Teddybear is offline
Old 05-10-2019, 07:59 AM
Registered Member
They have 2 options for these i only got the 9600 Lumens cause they are cheaper but because i bought 2 sets one for my car and one for my wifes car and both are amazing im going with the 12000 Lumens for my fogs
Old 05-10-2019, 08:03 AM
Subsonic
Teddybear's Avatar
i was JUST going to ask which version lol
No issues with clearance behind the headlight assembly?
Old 05-10-2019, 08:15 AM
Registered Member
For the bulbs no they are pretty compact but to install then i had to remove the coolant reservoir for the passenger side and battery for the driver side they pop im no problem i recommend doing the driver passenger side first so you can make sure you have the polarity right.
Old 05-10-2019, 09:53 AM
Registered Member
dopeboy1's Avatar
Nice! We will have to see how they hold up over time. Can you post a link to the ones you bought?
dopeboy1 is offline
Old 05-10-2019, 09:59 AM
Registered Member
HIKARI 9005 LED 9600 Lumens HIKARI 9005 LED 9600 Lumens
Old 05-10-2019, 10:06 AM
Registered Member
Hopefully they can withstand some abuse from being on all the time, I live in Canada so we can see how well they hold up in the winter. According to Hikari they withstood a 7 day test being on constantly, and can withstand cold temps. Anyone looking to buy them and dont want to risk them burning out you can pull your DRL fuse so they only turn on with high beams. I want to see how good they are so im leaving the DRL fuse.
Old 05-10-2019, 10:16 AM
Registered Member
Heres a photo of the DRL during the day and some of the high beams and low beams with a color comparison
DRL
High beams
Low Beam with High beam (In person the High beams are more blue while the low beams are white)
Old 05-10-2019, 10:21 AM
Subsonic
Teddybear's Avatar
I'm in Toronto as well. For the Hi beams they should be ok, because they're high enough that water shouldn't affect the fan. But for fogs, mine didn't last a full year. Once winter hit, the added moisture killed the fans. I have dual colour led's for fogs, but may switch back to halogens...
Old 05-10-2019, 10:25 AM
Registered Member
These are somewhat water resistant so im hoping they will be fine. Im going to add switch backs too, and i bought a splitter that acts as a skid plate, so hopefully it will help keeping all the salt and water out.
Old 05-10-2019, 02:42 PM
Registered Member
I am in Toronto as well and I have been running PUTCO's (ribbon heat sinks) for DRL and FOGs and they have running running solid since 2017. Pictures are below....
https://acurazine.com/forums/fourth-...-953482/page2/
echodigital is offline
Old 05-10-2019, 03:58 PM
Registered Member
I was going to get ribbon heat sinks but then i heard in winters they tend to rust good to know that some brands last maybe next time ill grab a set of those
Old 05-11-2019, 11:45 PM
Registered Member
Installed the fog lights today the pictures dont do it justice the lights are crazy bright It took around 5 mins per bulb and they were a direct fit no error codes well worth the money the fogs are the Hikari 12000 lumen H11 bulbs.
Right Side Hikari 12000 lumen LED Left side OEM halogen
Factory Halogens
Hikari fogs
Fog light beam pattern
Low beams
Low beams with fogs
Low beam
Low beam with fogs
Old 05-15-2019, 12:24 PM
Registered Member
Diode dynamic switchbacks installed took about 5 mins to change i didnt remove the bumper. They match my LED's almost perfectly i didnt install resistors because i dont mind hyperblinking for all the bulbs (high, fogs, signals) it costed me $267.52CAD including paypal exchange rates and shipping it would have been less if i got the 9600 lumens bulbs for fogs but i wanted to see the difference between the two its not much so definately just get the 9600 lumen bulbs if you looking to change them out. Either way all were well worth the money considering i was going to get HID fogs installed for $300.
Diode Dynamics (05-15-2019)
Old 05-15-2019, 07:12 PM
Registered Member
dopeboy1's Avatar
Looks good I'll probably grab those drl/high beams in the future.
dopeboy1 is offline
Old 05-15-2019, 08:15 PM
Subsonic
Teddybear's Avatar
I wanna see these in person!
Old 05-15-2019, 08:20 PM
Registered Member
They are 100% worth it i drive on backroads every now and then they are amazing for visability
Registered Member
If you're in the Brampton area come through
Old 05-21-2019, 12:09 PM
Registered Member
Are the LED DRLs on in your photo with the HID low beam? Hard to tell from the photos, but they look bright enough to blind people since they don't cutoff. I'll be excited if this is finally an LED that does DRLs right AND has high beam functionality. Unfortunately it's always been one or the other in the past.
meowmeows is offline
Old 05-21-2019, 12:37 PM
Registered Member
DRL don't turn on with the low beams. But these do work with DRL and High beam, for the DRL ive never been flashed and they are bright. They do dim down for DRL and with the high beams it lights up everything so far they have held up great i did some headlight correction and they look even better now.
missiehb
Second Generation RL (2005-2012)
02-01-2018 10:13 PM
GroundedCustom
Second Generation CL Discussion (2000-2003)
01-18-2016 08:08 AM
goalie29
Second Generation TSX Discussion (2009-2014)
25
01-15-2015 10:38 PM
HeLLy
Fourth Generation TL (2009-2014)
11-28-2011 05:01 PM
John in BC
First Generation TSX Discussion (2004-2008)
04-04-2004 06:46 PM
Quick Reply: LED high beams upgrade
