LED headlights - AcuraZine - Acura Enthusiast Community
Notices
LED headlights
Old 08-13-2018, 12:15 AM
Registered Member
LED headlights
I am wanting to change my daytime/high beam, fog, and get led switch backs for my car. What are some bright 6000k led out there and that are a good brand and good output light pattern. Some brands i looked into are
Auxbeam
Fluxbeam
Vleds
Opt7
Anyone let me know they are or other bright leds
jchand9 is offline
Old 08-13-2018, 12:45 AM
Theretrofitsource has good LEDs
thoiboi is offline
Old 08-16-2018, 03:18 PM
Registered Member
I used Putco. It uses a ribbon heat sink. No moving parts...
https://acurazine.com/forums/fourth-...-953482/page2/
echodigital is offline
The Following User Says Thank You to echodigital For This Useful Post:
shaade (08-22-2018)
Old 11-02-2018, 02:10 PM
Registered Member
I went with the cheaper iJDMtoy LEDs. They come with resistors so you won't get any error lights on the dash. They aren't freaky bright, but still enough to do their job and in the dark the oem headlights are bright as hell alongside them.
alexpeters is offline
Old 02-03-2019, 06:19 AM
New Member
Hi! are LED bulbs in the DRL/high beam reflector work properly? DRL are noticeably darker?
cairo333 is offline
Old 02-04-2019, 02:54 PM
Registered Member
No issue. The newer LEDs are so bright so running lower voltage is not an issue on DRL. I used Putco's on DRL and Fogs since 04-29-2017 through 2.5 Canadian Winters and they are still going strong. If your TL is 2012 or newer, I would get the Morimoto Fogs.
Xxb005txx
01-10-2014 10:09 AM
itsjac
07-27-2008 06:05 AM
IDSTL
04-06-2008 03:52 PM
Second Generation TL (1999-2003)
02-26-2003 02:41 AM
Quick Reply: LED headlights
