Interior lighting
I am a bullet proof tiger
Here is a big lighting thread.
https://acurazine.com/forums/4g-tl-2009-2014-123/lighting-722046/
The size you will need is 74 . Here is what I used for the armrest.
http://v-leds.com/Interior-LED/Gauge...81071-3-1.html
The armrest isnt that hard, however I seached and found a DIY from another gen TL, they are set up the same on the 4G. The glovebox i messed with for a while, before finally giving up, I never open it and its a PITA to get to.
Both just pop out. Arm rest is harder.
Pretty big selection of LEDs here:
http://www.autolumination.com/
The site looks amateur and sketchy, but I've order TONS from them and never had any issue.
Hey buckvegas, I see your signature you swap out 85122+. I have that bulbs and want to swap out too. Do you see big difference between stock and 85122+?
Is it easy to just swap out the bulb? Do I need to remove bumper?
See you swap your len on another thread and it's amazing, but I don't think I can or want to do that
Its no more yellow than the stock bulb imo. To me it looks white, the output is a lot better than stock. I like the color, sometimes those 6000K white bulbs look blue.
Guys, I can do everything except center console and glove box. Can you give me some more hints (buckvegas and CleanCL)?
I can pop the whole thing out a bit but don't see how to get to the bulb. Should I slide the white plastic cover off the base back plastic in some direction or ...?
tsx256kxd (11-22-2011)
handsom-hustla
11-13-2015 05:04 PM
oyayjoe
09-12-2015 04:40 PM
