Help on rear turn signals
So guys I have a 2013 Acura TL and ha very a huge question. I want to change out the turn signals in the back of the car and change them to leds 1st is it going to set off a code error on the dash, 2nd what kind of bulb is it, 3rd do they even make an led bulb for it, 4th where do I buy the led turn signals, 5th are they amber? Help would be greatly appreciated. Thanks guys.
1. No codes will show but you will have hyper flash, install 50w 6-Ohm resistors to fix it.
2. You will need two 7443 led bulbs.
3. and 4. I got mine from amazon and they are brighter than stock, you can find better more expensive bulbs but this perform great for the price.
5. they are bright amber. Links for resistors
Hope it helps,
Hope it helps,
