Sponsored by: DashLynx
Headlights recommendation
Old 03-21-2018, 09:06 AM
6th Gear
Cryptonoobie's Avatar
Hello AcuraZine,
I am new to the forum, however, not new to Acura.
One of my headlight bulbs is burning out, and I would like to get a recommendation on which bulbs I should consider purchasing.
I have a 2010 Acura TL, with converted fog lights to HIDs 5000K. My fogs have a tiny hint of blue but I was aiming for pure white (or hyper white?).
What do you recommend as far as something that will match my fogs with minimum hint of blue or yellow. I am looking for something bright and as white as possible.
Thank you,
CryptoNoobie
Old 03-21-2018, 09:11 AM
Received 16,260 Likes on 11,971 Posts
if you want to match your fog lights, you'll need to buy that brand of HID's..
Each manufacture has different manufacturing processes, which will make each light a different hue, even tho they are all labeled as 5000 Kelvin.
Just to note; 4300 Kelvin to 4500 Kelvin is stock.
4500 - 5500 kelvin would give off a "whiter/bluer hue"
and anything beyond 5500 kelvin will shift to purple.
but again, each manufacture has different processes...
Old 03-21-2018, 09:15 AM
6th Gear
Thanks for your explanation. I didn't realize that it varied as much per manufacturer. I'm mostly interested in purchasing a direct replacement bulbs without HID kit that would shine pure white. Any recommendations?
Old 03-21-2018, 09:19 AM
Received 8,584 Likes on 6,630 Posts
pick your poison:
https://www.theretrofitsource.com/hi...-d-series.html
D2S is your bulb size.
Old 03-21-2018, 09:25 AM
^ive had great luck with the Morimotos from www.theretrofitsource.com
they're only $50 and you can get them in the 5000 Kelvin range that will give off a "cool white light"
or you could spend the dough on a more expensive OEM set..the Osram CBI's (Cool Blue intensity) or even the newer Osram CBB's (Cool Blue Boost)
Old 03-21-2018, 09:31 AM
6th Gear
What life time did you experience with either of the bulbs?
Old 03-21-2018, 09:35 AM
in my 2006 Acura TL, I'm still rocking the OEM Osram set from 2006.
in my 2012 Kia Sportage; I bought 5000K morimotos in 2012. the bulbs are still going strong, but one of the ballast has failed.
Old 03-21-2018, 09:37 AM
6th Gear
Will I need to upgrade anything in my car besides swapping the bulbs?
Old 03-21-2018, 09:38 AM
you will only need D2S bulbs.
Old 03-21-2018, 09:41 AM
here's what the $50 morimoto bulbs look like in the Kia
Old 03-21-2018, 10:13 AM
3 years 5 months and 2 days
Old 03-21-2018, 02:06 PM
6th Gear
Look great!
Old 03-21-2018, 03:26 PM
6th Gear
For the retro store, is the difference in d serirs bulbs worth the steep price increase?
Xxb005txx
01-10-2014 10:09 AM
EdgarFanCLS
Cooking & Dining
09-03-2003 11:45 PM
bobowah_RENAMED
02-02-2002 12:21 AM
jit
Technology
01-26-2002 06:44 AM
Quick Reply: Headlights recommendation
