G-005: How-To: Install an HID Fog Light kit on a 4th gen TL
#41
Is there any legal issues with the HID fog lights? Will they blind on-coming traffic? I tried the easy route with bright halogens (Phillips Crystal Vision Ultra) but there is barley a difference between them and stock. My other options are LEDs which I listed below. Thank you
http://store.ijdmtoy.com/CREE-High-P...s-p/sku-4q.htm
http://www.v-leds.com/5K-WHITE-28-LE...24328-1-2.html
#42
#43
Fogs are intended to light up the road surface. They point down so they will not shine in the eyes of oncoming traffic.
I don't think you'll even get as bright as the halogens with the LEDs, but I could be wrong.
#44
Would being too bright affect their usefulness in the fog?
#46
#47
OP would the 55W or the 75W be drastically brighter than the 35W slim? and if I were to go with either of the aforementioned options would i need to drop a relay into the wiring harness before I hit the connector? I'm assuming I could go with a relay on each side, hot into one input, switch leg into a second, line out to a 3rd and then the ground out to the 4th...
Any help is greatly appreciated.
#48
35watt is the safest you want to go in the TL. 55watt or higher you take a chance on burning wires, melting the lenses, etc. No reason to go that high.
#50
did you buy the entire kit from HID extra for the headlights as well? I'm assuming the bulbs are the same in the 4 kits and it is just the ballast that differs...but can I just buy the 6k bulbs to match the fogs and switchbacks?
#52
Leather so soft.
Many many thanks to pippin-tl! I would have never made all the mods last weekend if it weren't for your detailed directions with pics.
I did the HID fogs and as long as i had the bottom shields down I installed some Bi-color 57 LED turn signals plus I put in some 128 -SMD LED DRLs. Here is a pic and thanks again "pimpin-tl".
Low beams Switchbacks and HID fogs
LED DRLs and new switchbacks
hey what code/bulb are the "switch backs" replacement.
#53
3k fog lights
I had 5k bulbs initially, but they were too blue for my liking and really didn't help much in the fog. Now I have 3k installed and they are decent and help with visibility in inclement weather. Wanted to post pictures for reference and those who are interested in what they look like.
I-Four (03-10-2013)
#56
Finally installed mine yesterday. Thanks so much for the instructions. They were very detailed. The only struggle I had was in actually getting the bulb to install in the housing. It is a very tight fit.
Also, it seems the newer 4G TLs have different bolts and clips on the shields on the bottom. I didn't have as many as you show in your DIY.
Pics will come later as soon as I am able to mask out the license plate numbers. I got the 6K and they are a little more blue than I would have liked, but will swap those out at a later date.
#57
Can anyone recommend a good brand of HIDs? I bought a set from HID extra and they were crap. First kit they sent me had a bad ballast, second kit had a bad bulb. So I just returned both and got a refund.
#60
Pimpin - Just sharing my experience, but I think you've been one of the luckier ones or perhaps, I've been unlucky. I ordered a set through HID Extra but spent a ridiculous amount of time trying to get 2 good ballast working at the same time. I'll give them some credit though, and their customer service is great sending replacement parts quickly. After going through 3 bad ballasts and not happy with the actual color output, I through in the towel and ordered a set from The Retrofit Source (3five ballasts). I've been very happy with the 3five set and would recommend them. Pretty good warm up time and no flicker.
#67
I ended up having to use a relay to get my passenger side fog lights working. I have a 2011 tl. Idk if its just my car. Did anyone else have this problem? I used the same hidextra kit
#68
Like I mentioned I never had any issues. I wanted a slightly more blue tint on mine and is the reason I went with 6k. I matched the headlights with the fogs. If you want more white, get 5k.
It seems people are having issues with HIDExtra recently. I am unsure why, but I would recommend looking at the source above before ordering them and see if they are a more reliable source.
#69
Not sure where CamPhil got his kit but I got mine from ebay here:
http://www.ebay.com/itm/171075014633?ru=http%3A%2F%2Fwww.ebay.com%2Fsch%2Fi.html%3F_sacat%3D0%26_nkw%3D171075014633%26_rdc%3D1
and they came package the same as in his first picture. I think they are the same slim kit as:
http://www.hidextra.com/h11/
Can anyone confirm?
They look identical to these:
http://www.ddmtuning.com/Products/DD...ast-35W-or-55W
Can anyone confirm?
#71
I'm looking at the 35W fog lights kit at ddmtuning.com and can't decide if 6000k or 5000k should be chosen to match the stock low beam HID's. Any suggestions? Also, I don't think I need the relay or the adapter cables for the 2010 TL. Thanks in advance.
#72
I went with the 6000K, I think they are going to match the best. From what I have read here and on DDM's site, you should not need the relay. I should be getting my kit in this week and will report back.
#73
I have 6k in both and my fogs still have more blue.
thePearl (12-10-2013)
#78
2011 SH-AWD 6MT
The color will never truly match because of the different type of housings. The stock headlights are projector housings which actually produce a different color above the cutoff line than below the cutoff.
The fogs are halogen reflectors and will largely spill a mess of color everywhere.
#79
My fogs just quit working. Both of them. Hard to believe it could be the fuses or the bulbs given both went out at the same time, but I will check.
I have the same set up as the OP. Any ideas what it could be?
#80
Thanks for posting these directions. My lens casing cracked and I think I'll try it on my own. The dealer quoted $360. Can I find the pictures somewhere else? Some of the links are broken and I don't feel comfortable attempting without those pics showing. Thanks for your help!
