Drl/highs?
Old 05-02-2017, 01:08 AM
8th Gear
SHawdyswingmyway's Avatar
Question Drl/highs?
Yes, I searched. I didn't get the exact answers I was looking for though. So, like everyone else, I want to get rid of my ugly running lights. I was thinking about just getting some Silver Stars and popping those in because it's the exact color I want in a high beam and daytime running light.... BUT.... Would they be the same desired color ( white-ish ) when just on DRL's? I understand the voltage drops for the daytime... I would hate for them to dull out like they are currently. If they will stay white on DRL andddddd high beam, then I'm just going to do it. I figure it wont throw any weird codes because the bulbs would be to OEM spec.
The LED set up's seem excessive with the resistors and extra wires to keep the sensors happy, etc. I just want plug and play, oem style.
Final goal ::: white light with DRL and high beam with no dash warnings.
Does this sound like a good plan?
Old 05-02-2017, 12:05 PM
The inconvenient truth
dopeboy1's Avatar
Sounds like a great plan.... whether or not it is possible is another story. I was in the exact same position, hating the yellowish stock daytime running lights. I didn't think bulbs like silver stars would be white enough. So I went with LED. They are really easy plug and play without throwing any codes and cost me I think about $45. After looking up the install in the internet it took me maybe 20 minutes to put in. Thing is that they don't have a high beam.... but if your headlights and fog lights are working properly then they should provide more than enough light. I think they look pretty sweet for daytime. So I decided to go with LED and haven't regretted it for a moment.
SHawdyswingmyway (05-03-2017)
Old 05-02-2017, 02:07 PM
Ghettopops's Avatar
By plug and play do you mean that literally? Sorry just a novice here. And what brand did you go with?
Old 05-02-2017, 02:12 PM
Received 8,712 Likes on 6,719 Posts
Go with the silverstars and hope the DRL light is to your liking
Old 05-02-2017, 02:37 PM
Keeping TL until 2029
echodigital's Avatar
I installed the following on my car (SYLVANIA 9005 SilverStar zXe High Performance Halogen Headlight Bulb) and they are still a bit yellowish when in DRL mode. When in HI beam, it appears to be more 'whiter'. IMHO, the only way to get a white looking bulb is to go LED.
If there is another SilverStar that is better - > please share!
I went with these ones (made in the USA) recently...
Putco 289005 (9005 DRL) - > includes flicker module but probably not needed. I got it just in case.
Putco 280011 (H11 FOG) - > includes flicker module but probably not needed. I got it just in case.
It is plug and play with a small box to resist the voltage because LEDs use less power than Halogens.
To summarize the CM DEAL post:
1. Try to get a weave heat sink. There are no moving parts to breakdown.
2. Have a 7.5 fuse just in case there is a problem with the DRL not working later. NOTE: If you have the parking brake on, the DRL will be off when you start the car.
3. LEDs are the way to go. The technology has changed a lot in the last 3-5 years. They are much now much brighter than the halogens. Don't buy cheap ones, you pay for what you get.
4. DRL in low and high beam is still pretty bright compared to halogens.
5. www.vleds.com's 9005 with weave heat sink appears to not be sold anymore. (CM DEAL post)
Many pictures are here (in DRL/Fog/Switchbacks):
https://acurazine.com/forums/fourth-...pgrade-953482/
How hot do LED headlight bulbs get? ? Better Automotive Lighting
Old 05-02-2017, 03:54 PM
dopeboy1's Avatar
They are literally plug and play except you are supposed to mount the resistors to metal but that's really easy too. I bought these ones here.
https://www.amazon.ca/iJDMTOY-16-CREE-9005-LED-High/dp/B01I0I5T5Y/ref=sr_1_2?s=automotive&ie=UTF8&qid=1493758254&sr=1-2&keywords=drl+2012+acura+tl+led https://www.amazon.ca/iJDMTOY-16-CREE-9005-LED-High/dp/B01I0I5T5Y/ref=sr_1_2?s=automotive&ie=UTF8&qid=1493758254&sr=1-2&keywords=drl+2012+acura+tl+led
Old 05-03-2017, 10:34 AM
This video is really good to show you what technology is out there:
I went with the braided heat sink because it's a newer design.
The following 2 users liked this post by echodigital:
fryrice (07-31-2017), TuroTL (10-06-2018)
Old 05-03-2017, 11:09 AM
8th Gear
Thanks for the feedback! I'll just grab some silverstars and see how they do. At least my high beams will be whiter at worst I guess. I live in Kentucky and sometimes need a good high beam on the back roads. Might do LED later.
echodigital (05-03-2017)
Old 05-04-2017, 04:58 PM
TLTesh604's Avatar
Please let us know how you like them, maybe a picture if you can.
Old 05-04-2017, 05:01 PM
8th Gear
Most definitely 👍🏻👍🏻👍🏻
Old 09-30-2018, 05:53 PM
ekhngai's Avatar
Drl led putco
https://acurazine.com/forums/"http://betterautomotivelighting.com/2016/11/12/how-hot-do-led-headlight-bulbs-get/""]How hot do LED headlight bulbs get? ? Better Automotive Lighting[/url]
Hi Echo, would i still need to purchase the CANBUS decoder to prevent error messages for the putco LEDS?
