Driver Side Mirror Housing Replacement / Gap Between Mirror Edge and Housing
Hello.
Does anyone know where I can find information on how to remove / replace only the outer housing on the left / driver side mirror?
I don't see how and why I would need to remove the entire mirror from the door panel etc...
Also,
Is it normal to have a gap between the inside glass portion edge and the housing? I want to make sure mine is normal compared to others.
Any help on the housing replacement would be appreciated!
Thanks!
Also,
Thanks!
Hello.
Also,
Thanks!
Also,
Thanks!
The Sicilian
Here is a diagram of the mirror. Maybe someone can provide more detail,but I still think your going to have to take it off the car in order to take it apart.
http://oemacuraparts.com/partlocator...layCatalogid=0
Thanks.
Yea I got a similar one from the Acura eStore. Thats insane if you have to remove the door panel. There has to be an easier way. Its only the shell / housing that I need to replace. Not the guts inside the mirror.
Do you know where I can get the 2010 TL Service Manual?
I guess it depends on how much of a gap you're talking about. There has to be some gap because the mirror needs to move around in there. The way I have my mirrors aligned there's actually a rather significant gap because the mirrors face pretty for out to either side.
TLGuyNJ (10-11-2011)
Thanks!
nanos
11-12-2015 08:41 PM
