Clarification needed please...B123 service
Old 12-22-2013, 08:33 AM
moabizzi
MoAbbas's Avatar
I have a B123 service reminder popping up.
oil change, cabin filter, tranny fluid, transfer case fluid, tire rotation.
for the tranny fluid and transfer case, is this a drain and fill, or is it a full flush reminder?
and how much tranny fluid do i need to order?
i can make a DIY if needed aswell.
Old 12-22-2013, 11:17 AM
heisnuts's Avatar
The transfer unit is a drain and refill. You might be fine with just one quart for the transfer unit, but if it were me, I would have 2 quarts on hand to make sure I had enough. The transmission will need a little under 4 quarts if you are doing a drain and fill. Some like to replace more than that by doing a drain and fill 3 times with driving in between each drain and fill to get 12 quarts of fluid changed out.
The following 3 users liked this post by heisnuts:
MoAbbas (12-22-2013), Reorge (12-22-2013), shurik74 (12-22-2013)
Old 12-22-2013, 11:22 AM
potmilkz's Avatar
Received 1,020 Likes on 792 Posts
Old 12-22-2013, 01:54 PM
moabizzi
MoAbbas's Avatar
im looking for the ATF on curry acura, is that the best way to go? any reccomendations on tranny oil?
Old 12-22-2013, 02:13 PM
Reorge's Avatar
I changed the fluids in my transfer case and rear differential last March.
Transfer case: 0.45qt (per 2012 SERVICE manual). I spilled some and still have remnants in the bottle from the 1 qt I purchased.
Rear Differential: 2.67qt (per 2012 SERVICE manual). I had 3 qts on hand and didn't use all from the third qt. You WILL need an oil bottle pump.
I also used all new plug washers.
Old 01-08-2014, 05:03 PM
moabizzi
MoAbbas's Avatar
i recently did my rear diff, so i wont need to do that, but i need to order the tranny oil from curry acura, weather just cleared up here in NJ, gonna be low 50s this weekend, looking to a lot of work on the car this weekend.
can anyone help me out and give me the name or even the item number of the tranny oil i should order?
Old 01-08-2014, 05:52 PM
moabizzi
MoAbbas's Avatar
ATF DW1 - Acura SKU
082009008A
$6.42 per quart
does the transfer case use the same or does it use the DPSF like the rear diff?
Old 01-09-2014, 06:54 PM
Art unique's Avatar
ATF DW1 - Acura SKU
082009008A
$6.42 per quart
The owners manual gives you all of this info. If you still cant find it download my service manual
MoAbbas (01-13-2014)
Old 01-13-2014, 12:10 AM
moabizzi
MoAbbas's Avatar
im looking at the service manual, (got it from another source earlier, but thanks for the offer), and i cant find where it says anything about the front differential. i bought 4qts of DW1 and 1 of the DPSF. can anyone give me a heads up of where to look?
notfast
1/2G MDX (2001-2013)
03-28-2023 08:10 AM
02-25-2020 09:57 AM
wusty23jd
09-24-2015 11:41 AM
1siccdc2
09-06-2015 06:59 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: Clarification needed please...B123 service
