Check Charging system??
Old Dec 15, 2017 | 12:31 PM
john6699's Avatar
I looked at a 2010 Acura TL runs great Once I opened it up on the road the "Check Charging System" light came on and off then back on it didn't stay on. Guy replaced the Battery and Alternator from pepboys.
Not sure if it someone simple or can cost me $$$$
Is there a know problem easy fix for this issue. Is it possible from water damage
Old Dec 15, 2017 | 12:44 PM
loose battery clamp or loose belt on alternator perhaps
Old Dec 15, 2017 | 01:17 PM
john6699's Avatar
I am scared that it is something computer or electrical that would cost alo of money. Maybe the Tension pulley?
Old Dec 15, 2017 | 05:40 PM
john6699's Avatar
The Owner of the car claims this is what needs to be replaced. I don't know how one would be sure that was the issue. Buying a used 8 year car is scary and tricky
ALTERNATOR REGULATOR PLUG PIGTAIL
Amazon Amazon
please give sugguestions
thank you
Old Dec 16, 2017 | 09:55 AM
MarcoNorthPolo's Avatar
KCCO
If you have reservations, then don’t buy it. There are plenty out there that don’t need any repairs.
Old Dec 19, 2017 | 12:55 PM
2snail's Avatar
FYI, the duralast alternator is spotty with reliability. I went that route for out AWD SH TL and after 1 year it crapped out and threw the check charging system message. I had pepboys install a denso one which in their systems states its the oem brand.
Since all the newer cars rely on the computers they get pretty finicky once the power system has issues/ weak car battery etc. I am on like the third car battery for our TL.
As long as the car has a good maintenance history with oil changes and no accidents you should be in good shape. Maybe check the oil level to see if its one of the oil burning 4g's. Also check to see if there is a whining/whistle noise at highway speeds which is the propeller shaft bearing.
Old Dec 19, 2017 | 01:31 PM
DENSO is OEM supplier
lareacap
Jul 25, 2019 09:42 AM
jfwalker2
4G TL Problems & Fixes
Oct 1, 2017 01:25 PM
wmahmud
41
Jan 3, 2017 11:12 AM
Courtney Lopez
14
Nov 3, 2012 12:24 AM
xjbych2810
Aug 26, 2011 07:12 PM
