Check Keyless Starting System Error
This is the message I got.
This morning I remote started my car and went to open my door using the keyless entry with the door handles, car remained on which was odd since this generation of Acura shut off immediately upon opening the door. I then got in and put my foot on the brake, the car instantly shut off and I restarted it fine. While driving in the highway I get the a flashing error message check keyless starting system. Anyone have this happen to them with a car that has an aftermarket remote start like Viper?
I am only taken an educated guess. It could be possible that the door switch did not make good contact to the ground. That would explain why the car did not cut off and might have contributed to your error message. I would try just pushing the doorswitch in and out with your hand to make sure its working properly. You can check to make sure the dome light cuts on and off with the door switch.
wmahmud
4G TL Problems & Fixes
41
01-03-2017 11:12 AM
El_Illution
10-17-2013 03:02 PM
MustBeTL
01-05-2012 09:54 AM
helraiser
1G TSX Problems & Fixes
05-26-2008 10:35 PM
