Car and Driver Article about AWD Systems - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 07-02-2016, 10:28 PM   #1
Registered Member
This month's issue is an interesting read. It ends with them being impressed by and saying many positive things about torque vectoring capabilities on the top level Ford and the TLX. I wish they had mentioned that the other auto makers are really playing catch up here and Acura's SH-AWD system has been doing this for years. The article also mentions that the torque vectoring systems are hard (thermally) on the oil. I've also heard the rear diff in our SH-AWD Acuras is hard on the oil and that the shearing action beats the oil up a lot. So, even if it looks perfectly clean, it seems wise to follow the interval recommendation for changes. I do the rear diff, transfer case, the simple (one time) drain and fill of the tranny once a year and I'll still do the 3 times on the transition fluid at 60K or whatever. But give Acura accolades for using torque vectoring before it was popular. Sounds like we will be seeing more and more torque vectoring in the future.
WNY PAT is offline   Reply With Quote
Old 07-03-2016, 05:12 AM   #2
4G TL-Elilte, 3G MDX
It is true that other automakers are catching up to the Honda torque-vectoring AWD system.
That's why the advent of the tri-motor hybrid AWD system from Honda to stay ahead of the game.
Edward'TLS is offline   Reply With Quote
Old 07-03-2016, 12:06 PM   #3
Registered Member
Reorge's Avatar
Thanks for the info. I change my diff fluid every 15k miles; it's prob overkill but it's my choice.
It's easy to do even for a 52 year old semi-white-collar man. I don't even jack up the car.
Reorge is offline   Reply With Quote
Old 07-03-2016, 07:27 PM   #4
Registered Member
You sir...are thinner than I.
I did it once on the TL, somewhere here on AZ there is a picture of me with my gut hanging out while laying on the garage floor.
Mr Marco is offline   Reply With Quote
Old 07-07-2016, 03:38 PM   #5
Registered Member
is there a way to see this article online?
a google search failed to find the article
I'm assuming it was the July issue?
azsportpilot is offline   Reply With Quote
Old 07-07-2016, 03:44 PM   #6
Registered Member
mossman77's Avatar
Am I the only one that was unable to get the drain and refill plugs loose? I was using a 24" breaker bar, but could only get it on the bolt one way and there was not enough clearance between the bar and pavement to do much of anything. I had the back end up on ramps.
mossman77 is offline   Reply With Quote
Old 07-07-2016, 04:23 PM   #7
Registered Member
Reorge's Avatar
Quote:
I remember the first time change the plugs were a little tight. I did jack it up the first time but I don't remember having that much difficulty.
I assume you know to always remove the fill plug first when draining a gearbox or transmission. If you drain it first and can't remove the fill plug, you're SOL and in need of a tow truck (or the car is not drivable until you can get the fill plug loose).
There are multiple threads on this forum that show how to perform this job (with pictures).
Old 07-07-2016, 04:38 PM   #8
LNJ
Registered Member
LNJ's Avatar
Quote:
Actually it is not as hard on our rear differential as the new current SH-AWD on the TLX and 2016 MDX. Ours is electromagnetic based and the new one is hydraulic based which is much harder on the gears and can heat up more during prolonged use.
LNJ is offline   Reply With Quote
Old 07-07-2016, 04:55 PM   #9
LNJ
Registered Member
LNJ's Avatar
The Following 2 Users Say Thank You to LNJ For This Useful Post:
echodigital (07-08-2016), Reorge (07-07-2016)
Old 07-07-2016, 05:14 PM   #10
LNJ
Registered Member
LNJ's Avatar
Forgot to add this one: AutoZine Technical School
Old 07-08-2016, 09:24 AM   #11
Registered Member
thanks, this will tide me over until i can find a copy of the Car & Driver article
Old 07-09-2016, 11:20 PM   #12
csmeance's Avatar
acura's original electromechanical SH-AWD found on our cars, the 2G MDX, 2G RL also have magnetic clutches! Newer SH-AWD system in the TLX is a more traditional AWD system!
csmeance is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
That white Type S... mdnborg's Progress Thread mdnborg 3G TL Photograph Gallery 289 01-09-2018 09:17 PM
Jaguar: F-Type News **SVR Versions Revealed (page 4)** gavriil Automotive News 143 04-12-2017 02:19 PM
CLOSED: 2005 Acura RL (Legend) Air Ride, Show car Elkhart, Indiana Carbon Legend Member Cars for Sale 17 08-05-2016 06:21 PM
Mazda: CX-4 News 00TL-P3.2 Automotive News 14 05-02-2016 10:10 AM
If it wasn't a TLX, what would it have been? neil0311 Fifth Generation TLX (2015+) 82 04-16-2016 04:59 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
