best engine oil 2009 acura tl engine oil
Latent car nut
Received 2,005 Likes
There is no such a thing as "the best engine oil for a 2009 Acura TL", errr, unless you're religious, then it is whichever oil you worship.
Long story short, literally any 0W-20 will do a good job of lubricating your engine, as will most 5W-20s.
Pearson4G (02-01-2018)
the priciest one you can find
I'm glad you brought this up. It's never really been discussed before.
When it comes to oil, what's 90% important is that you change it on time. The other 10% is what oil and filter you choose. Heck, use the $11 Walmart Supertech special and it will be just fine.
I personally use Mobil 1 Extended Performance with the Mobil 1 Extended Performance M1-104 filter. I consider it money well spent considering the oil and filter is about $20 more per change than the Walmart oil and basic Fram filter. Two oil changes per year or so = $40 more per year. Small cost for theoretically better engine protection.
I use Royal purple oil and filter. I change the oil once a year. My 09 runs and sounds like the day I bought it. I am very confident the car is being lubed and protected properly.
Latent car nut
I use Castrol Edge 0W-20. So?
So what that leaves us with is the following vote totals:
Long story short, the price if tea in China will not be affected by the oil you put in your engine.
- QTY - Brand/Product
- 001 - Castrol Edge
- 001 - Mobil 1
- 001 - Pennzoil Platinum
- 001 - Royal Purple
acurakid_slc
10-16-2023 11:59 AM
rets
09-09-2013 02:43 PM
