Alarm Issues 4th Gen TL
Hello guys, when purchasing my 2013 Acura TL Tech I had an odd problem where my driver 1 key wouldn't respond at all. I was only able to open the door with the key insert. Push start worked also. Driver 2 key was lost before I even purchased the vehicle so they gave me an aftermarket replacement key and programmed the original key to work again. Everything is working now regarding keyless entry. They just warned me not to insert the key fob into the modular due to it being defective. I want an aftermarket alarm will I run into issues?
Is the car under warranty? If so just get the Fob and such sorted out
If not I would still go to the dealer/or local shop that is able and get your key sorted out, however that is just me.
or search the forum and see if you can get an actual new Acura key fob reassigned to your car
Why can you not put your fob in your slot?
You are under the mileage for the full warranty (4/50k)
and
Warranty transferability (According to the Owner site)
Acura warrantees the vehicle regardless of the number of ownership changes it incurs. In fact, the back cover of your Acura Warranty Information booklet contains a "Change of Address or Ownership Notification" form for that purpose. In case of safety recalls, product updates, etc., we need to know who to notify. Whenever you move or sell the car, please complete the form and send it to us promptly.
Perhaps you can get the dealer to solve for free or nearly free
and
and
and
These are some pics of the key slot for the key fob. It looks pushed out.
So I went to the Acura Dealer today and discovered that my warranty had expired even tho I'm under the 50k mile warranty. So they quoted me $385 to fix the key slot. The service department guy told me that eventually my key fobs will drain and I won't be able to start my car due to the batteries inside them dying. Is this true?
Not exactly sure what they're talking about here. From the sounds of it your original key is working normally and you also have an aftermarket keyfob that works as well, is that right? The batteries in the original keyfobs can be replaced in like 2 minutes, they're just CR2032 cells. Maybe the service guy meant something else?
The inconvenient truth
Well I'm assuming he meant that the key slot is supposed to charge the battery in the key
I don't think that's how it works. ..
Checked the manual. In the section about the slot, it doesn't state that it charges the key and it even shows you how to change the battery when it gets low with no mention of using the slot
Just as I thought the dealer was trying to get me. I had a feeling the service guy was a liar. He didn't even wanna give me the $385 for the repair on paper as a quote.
Does anyone know if this is true, does the key slot charge the battery in the key? I used the key slot for like the first week of owning my car and haven't used it much since. I bet its been over a month since I've used the key slot. My first thought was that if the battery in the key dies then you should just replace it like you would any battery.
