Notices
Airbag System: 92-2
Old 04-18-2019, 06:13 PM
New Member
Airbag System: 92-2
First post, hi Acurazine!
I have 2012 Acura TL. I have been having an intermittent air bag light pop up. The msg appears on screen says Airbag System check: 92-2. It comes on about every other day and now itís stayed on every time I started the car? I did little bit of research and found out itís have something to do with the hazard switch Passenger AirBag Cutoff Indicator, or the pressure sensor in the seat. Today I was coming home from work. While I was driving, I hold the passenger head rest forwards the passenger airbag cutoff indicator light came off like itís supposed to because since no ones was setting there. As soon as I let go the passenger seat head rest, the indicator light went off? I have the video recorded, will post it up soon, please any help would appreciate Again, code stored was 92-2.
Acura_TL2012 is offline
Old 04-18-2019, 09:10 PM
csmeance's Avatar
Received 1,033 Likes on 722 Posts
csmeance is offline
Old 04-18-2019, 09:12 PM
csmeance's Avatar
csmeance is offline
Old 04-18-2019, 09:13 PM
csmeance's Avatar
csmeance is offline
Old 04-19-2019, 07:57 AM
New Member
Hazard switch removal
Thank you so much for the feedback, i much appreciate your helped! Just one thing how would I remove the hazard switch? Do I have to take out the CD changer, or Ac vent needs to be remove? Just the Hazard switch pops out?
Old 04-19-2019, 01:07 PM
csmeance's Avatar
csmeance is offline
Rhop09
1G TSX Problems & Fixes
04-08-2018 10:47 AM
Billu99tl
2G TSX Problems & Fixes
05-26-2016 03:26 AM
bluesolara
Second Generation CL Discussion (2000-2003)
11-27-2013 02:55 AM
n3o
05-05-2010 03:03 PM
Quick Reply: Airbag System: 92-2
