Sponsored by: DashLynx
Suspension noise?
Old 10-06-2018, 01:06 PM
OhhNoVtec's Avatar
Suspension noise?
i am currently changing out my upper control arms and noticed this making noise. Should there be this much play?
Old 10-06-2018, 04:32 PM
OhhNoVtec's Avatar
the video plays from my phone. is it working on your laptops or desktops?
Old 10-07-2018, 06:08 AM
frankjnjr's Avatar
Not working on my desktop!
Old 10-10-2018, 12:05 PM
losiglow's Avatar
It worked for me.
If the boot is not torn and you don't have play or noise when moving the hub right and left (other than the normal rotational movement between the ball joint and steering knuckle), then I'd probably leave it alone.
I replaced my outer tie rods a few months ago. The new ones were definitely "tigheter" than that but I think the most important thing is that they don't have play on the horizontal plane. Rocking back and forth like that is probably less critical. I'm not a suspension expert however. If you're up for changing them, they're relatively cheap on RockAuto.
jmbnova
03-10-2006 09:32 PM
Black2.3CL
01-10-2006 12:54 AM
PeterUbers
04-20-2004 05:42 AM
ngcreese
09-02-2001 06:24 AM
Quick Reply: Suspension noise?
