Notices
4G TL, no air out of passenger side vents
Old 05-21-2019, 01:12 PM
New Member
Looking for some info or help on d.i.y. to fix a problem.
A/C works just fine; cold/hot air comes out no problem. The issue is that air is only coming out of the driver-side top center and left side (by window) vent; no air is blowing out of the passenger-side top center and right side vent. Also notice that only the return vents under the passenger side is taking in air; the return vent under the driver side is not taking in air. I suspect that a vent/flap actuator has gone bad but how do I check to fix and also where in the car are they located for me to get at. Any suggestion would be greatly appreciated.
Dennis Kosi is offline
Old 05-22-2019, 04:05 PM
Registered Member
A search in the Problems and Fixes forum for "blend door" turns up these threads:
https://acurazine.com/forums/search....rchid=21242083
dregsfan is offline
Old 05-22-2019, 06:23 PM
Registered Member
Reorge's Avatar
Is the DUAL button illuminated. If so perhaps you have the temp set higher on the passenger side and/or you have the air mode set to "bottom" on the passenger side.
Reorge is offline
Dennis Kosi
4G TL Problems & Fixes
05-18-2019 06:08 PM
OTHREETLS
08-02-2017 04:41 PM
wasupdog
10-28-2013 10:52 AM
nepdb1
First Generation TL (1996-1998)
01-01-2007 09:05 PM
Tatewaki
Second Generation TL (1999-2003)
06-20-2003 04:00 PM
Quick Reply: 4G TL, no air out of passenger side vents
