AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   4G TL (2009-2014) (https://acurazine.com/forums/4g-tl-2009-2014-123/)
-   -   2014 Acura TL Technical Service Bulletins (https://acurazine.com/forums/4g-tl-2009-2014-123/2014-acura-tl-technical-service-bulletins-928636/)
EE4Life 04-03-2015 09:28 AM
2014 Acura TL Technical Service Bulletins:
TSB 13-031 - 2014 TL: TQI Information
Applies To: 2014 TL - All
http://www.urvi.net/forumfiles/SB/B13-031.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B13-031.PDF
TSB 13-032 - 2014 TL: TQI of the Navigation System
Applies To: 2014 TL With Navigation - All
http://www.urvi.net/forumfiles/SB/B13-032.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B13-032.PDF
TSB 14-027 - Moonroof Will Not Auto-Close or Reverses Direction
Applies To: 2009-14 TL - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-027.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-027.PDF
TSB 14-048 - New Warranty Instructions for TPMS-Related Repairs
Applies To: 2006-14 TL - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-048.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-048.PDF
TSB 14-049 - Gurgle or Chirp from Under Hood at Cold Start-Up
Applies To: 2012-14 TL - ALL with A/T - ALL
http://www.urvi.net/forumfiles/SB/B14-049.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-049.PDF
TSB 15-013 - Driver’s Seat Cushion Cover Comes Loose
Applies To: 2012-14 TL - Advance, Advance with SH-AWD - ALL
http://www.urvi.net/forumfiles/SB/B15-013.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-013.PDF
TSB 16-010 - Safety Recall: Takata Driver’s Airbag Inflator
Applies To: 2009-14 TL - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B16-010.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-010.PDF
TSB 16-046 - Judder from the Torque Converter Lock-Up Clutch
This bulletin is replaced by 18-047, 2012-14 TL: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required)
http://www.urvi.net/forumfiles/SB/B16-046.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-046.PDF
TSB 18-009 - Engine Oil Consumption Exceeds Client Expectations
The bulletin is replaced by S/B 19-006, Warranty Extension: Engine Oil Consumption Exceeds Client Expectations
http://www.urvi.net/forumfiles/SB/B18-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-009.PDF
TSB 18-020 - Warranty Extension: Customer Support Program For Driver's Airbag Inflator for 2013-14 ILX Hybrid and Other Listed Years and Models (Expires February 28, 2026)
http://www.urvi.net/forumfiles/SB/B18-020.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-020.PDF
TSB 18-047 - 2012-14 TL: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required)
Applies To: 2012 TL - 2WD - From VIN 19UUA8F...CA035307 thru 19UUA8F...CA040693
2012 TL - 4WD - From VIN 19UUA9F...CA011186 thru 19UUA9F...CA012783
2013-14 TL - ALL - ALL
http://www.urvi.net/forumfiles/SB/B18-047.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-047.PDF
TSB 18-048 - 2012-14 TL: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Upload Required)
http://www.urvi.net/forumfiles/SB/B18-048.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-048.PDF
TSB 19-006 - Warranty Extension: Engine Oil Consumption Exceeds Client Expectations
Applies To: 2009-14 TL - SH-AWD - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-006.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-006.PDF
TSB 19-018 - Safety Recall: Driver's Airbag Replacement Inflator Can Be Over-Pressurized
http://www.urvi.net/forumfiles/SB/B19-018.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-018.PDF
TSB 19-021 - Warranty Extension: Steering Feels Heavy, EPS Indicator Blinks with No DTCs or Comes On Steady with DTC 32-09, 32-08, or 61-04
Applies To: 2012-14 TL - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-021.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B19-021.PDF
TSB 19-043 - Safety Recall: Takata Driver's Airbag Inflator
http://www.urvi.net/forumfiles/SB/B19-043.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-043.PDF
TSB 19-052 - Warranty Extension: Engine Oil Consumption Exceeds Client Expectations
http://www.urvi.net/forumfiles/SB/B19-052.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-052.PDF
TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 1999-14 TL
http://www.urvi.net/forumfiles/SB/B19-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF
TSB 20-006 - Warranty Extension: Customer Support Program for Driver's Airbag Inflator for 2013 ILX and Other Listed Years and Models (Expires January 31, 2030)
http://www.urvi.net/forumfiles/SB/B20-006.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-006.PDF
EE4Life 11-08-2019 09:13 PM
Added new TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram.
kenRDX2019 02-12-2020 08:08 AM
I test drove Q3 and RDX I like RDX far more because the maintenance isn't expensive like Audi and Insurance are more affordable. Q3 only the premium plus s line worth to get and which will cost about the same as RDX. Might as well get a bigger SUV.
EE4Life 03-12-2020 07:30 PM
Added new TSB 20-006 - Warranty Extension: Customer Support Program for Driver's Airbag Inflator for 2013 ILX and Other Listed Years and Models (Expires January 31, 2030).
